So how much bigger can you go with your stock FI on a 2.0?, CC's that is... |
speed metal army |
Oct 29 2010, 08:46 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
And whats the reliable,proven formula when it comes to cams,pistons etc?
Thanks! |
BigDBass |
Oct 29 2010, 09:20 PM
Dumb Question Champion Group: Members Posts: 1,438 Joined: 11-January 06 From: Chicago (south 'burbs) Member No.: 5,405 Region Association: Upper MidWest |
I believe 2056 is about it with D-Jet with modified MPS.
speed metal army |
Oct 29 2010, 09:51 PM
DanT |
Oct 29 2010, 10:58 PM
96mm pistons/cylinders
tweaked MPS Raby 9550 cam |
speed metal army |
Oct 29 2010, 11:27 PM
Sleepin |
Oct 29 2010, 11:37 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
Sometimes a MPS adjustment is needed to richen things up a tad.
My wife's 2056 is running D-Jet with stock cam and no adjustments to the MPS....but, we are at 4600'. |
Bleyseng |
Oct 30 2010, 03:51 AM
witha stock cam no adjustment is needed but if you switch to a Raby 9550 cam then you need to adjust the MPS to set the AFR.
2056 Raby 9550 cam RAby lifters and valve train kit 115hp! |
speed metal army |
Oct 30 2010, 10:39 AM
Jake Raby |
Oct 30 2010, 01:41 PM
I believe 2056 is about it with D-Jet with modified MPS. OK,How bout some specifics?A parts list! -RAT 9550 valve train kit -RAT 96mm cylinder and piston kit from KB - 8-9:1 CR dependent upon operating elevation, deck height set to no more than .045 -42X36 valves in stock, non ported 2.0/914 heads (or RAT LE 180 3 stud heads) This combo currently nets around 120 FWHP and around 130 lb/ft of torque. It'll net around 100 RWHP on a chassis dyno, about the same on torque. With the LE 180 heads we are seeing 130HP and 140 TQ at the flywheel. Its all in the combo. Goof it up and it won't be tunable, stock EFI is very particular to every alteration made to the engine. This combo is exceptionally proven and has been applied for over a decade :-) The engine will run cooler, will make more power and will average better fuel economy through increased efficiency. |
speed metal army |
Oct 30 2010, 06:49 PM
I believe 2056 is about it with D-Jet with modified MPS. OK,How bout some specifics?A parts list! -RAT 9550 valve train kit -RAT 96mm cylinder and piston kit from KB - 8-9:1 CR dependent upon operating elevation, deck height set to no more than .045 -42X36 valves in stock, non ported 2.0/914 heads (or RAT LE 180 3 stud heads) This combo currently nets around 120 FWHP and around 130 lb/ft of torque. It'll net around 100 RWHP on a chassis dyno, about the same on torque. With the LE 180 heads we are seeing 130HP and 140 TQ at the flywheel. Its all in the combo. Goof it up and it won't be tunable, stock EFI is very particular to every alteration made to the engine. This combo is exceptionally proven and has been applied for over a decade :-) The engine will run cooler, will make more power and will average better fuel economy through increased efficiency. I want this stuff. (IMG:style_emoticons/default/smile.gif) |
majkos |
Oct 31 2010, 07:43 AM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
Sometimes a MPS adjustment is needed to richen things up a tad. My wife's 2056 is running D-Jet with stock cam and no adjustments to the MPS....but, we are at 4600'. Flatlanders (IMG:style_emoticons/default/biggrin.gif) |
majkos |
Oct 31 2010, 07:49 AM
I believe 2056 is about it with D-Jet with modified MPS. OK,How bout some specifics?A parts list! -RAT 9550 valve train kit -RAT 96mm cylinder and piston kit from KB - 8-9:1 CR dependent upon operating elevation, deck height set to no more than .045 -42X36 valves in stock, non ported 2.0/914 heads (or RAT LE 180 3 stud heads) This combo currently nets around 120 FWHP and around 130 lb/ft of torque. It'll net around 100 RWHP on a chassis dyno, about the same on torque. With the LE 180 heads we are seeing 130HP and 140 TQ at the flywheel. Its all in the combo. Goof it up and it won't be tunable, stock EFI is very particular to every alteration made to the engine. This combo is exceptionally proven and has been applied for over a decade :-) The engine will run cooler, will make more power and will average better fuel economy through increased efficiency. I want this stuff. (IMG:style_emoticons/default/smile.gif) You got me sold! Too bad I've no money (IMG:style_emoticons/default/sad.gif) But Ive still a running 914 (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 03:49 PM |
