8" Fuchs on stock-ish body, I finally tried it today... |
campbellcj |
Oct 30 2010, 07:58 PM
I finally bought some tires (Toyo RA1's) for my 15" Fuchs and put them on the car today. The fronts are 7's and the rears are 8's, which is pretty ambitious for a stock fendered car but it's been done before. (For the last several years I have been running 16x7's all around.)
Despite the significant rolling/pulling of the rear fenders, there is still a little rubbing. I will yank on them some more. They will likely be cut-off for flares sometime soon anyway, so it won't hurt anything. |
Oct 30 2010, 08:53 PM
Chris - I saw a 914 where someone tried the same thing and they really messed up the rear quarter of the car. When you tug on the metal too much, it starts pulling on the seams and welds and opens up the gaps slightly - Every action has an opposite and equal reaction.
pete-stevers |
Oct 30 2010, 09:41 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
that car looks ..super with the 8s
sww914 |
Oct 30 2010, 10:35 PM
Try some more rear negative camber if you can get it.
Looks good! |
PeeGreen 914 |
Oct 30 2010, 11:24 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
One of our locals has 8's all the way around with doing what you did. I would keep the narrow body and just get the lips out a little more. Maybe add a little more neg camber (IMG:style_emoticons/default/wink.gif) Flares just makes the car more cone prone.
campbellcj |
Oct 31 2010, 12:23 AM
This is just a temporary setup but I just need a teeny bit more clearance. Also I should be able to get a little more negative camber. It is 'only' at -1.5degs or so right now and the car needs a full competition alignment + corner balance again before next season starts up.
jimkelly |
Oct 31 2010, 07:11 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
OT
on a narrow body 914 with a V8 or suby - there is a ton of room between engine and rear trailing arm - i wonder if anyone widened the swing arm and moved the inner trailing arm mount inward a few inches? note that longer pivot shafts would be needed and custom axles too. Attached image(s) |
cary |
Oct 31 2010, 07:56 AM
One of our locals has 8's all the way around with doing what you did. I would keep the narrow body and just get the lips out a little more. Maybe add a little more neg camber (IMG:style_emoticons/default/wink.gif) Flares just makes the car more cone prone. Jon, is that the electrian guy with the silver 6? He parked next to me at Packwood. He had them stretched out and they looked great. |
0396 |
Oct 31 2010, 08:04 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
-6 looks great!
cary |
Oct 31 2010, 08:29 AM
I think this is his car with a side view.
brant |
Oct 31 2010, 08:41 AM
OT on a narrow body 914 with a V8 or suby - there is a ton of room between engine and rear trailing arm - i wonder if anyone widened the swing arm and moved the inner trailing arm mount inward a few inches? note that longer pivot shafts would be needed and custom axles too. but there isn't any room between the inner fender and the inboard side of the wheel/tire. Take a shock loose and compress the swingarm with the tire mounted. On the normal/commonly used rims like cookies or fuchs, you only have about 1/4 to 1/2 of inside clearance usually. So moving the swingarm inward will probably cause the tire to not only hit, but you may not be able to get the chassis off of the jack stands. brant |
Tom |
Oct 31 2010, 09:36 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
It tends to widen the door gaps a bit. Might want to keep an eye on that. Also pulls away from the bumper.
Tom |
EdwardBlume |
Oct 31 2010, 09:50 AM
I think this is his car with a side view. (IMG:style_emoticons/default/smilie_pokal.gif) This looks good... |
Tom |
Oct 31 2010, 10:17 AM
Ghia Specialties has a different way to make wider wheels/tires fit. I think his name is Kelly?
Tom |
jeff |
Oct 31 2010, 10:24 AM
Member Group: Members Posts: 252 Joined: 17-January 04 From: thousand oaks,ca Member No.: 1,570 |
Chris your car just keeps getting better!1 It's rolling art and i'd still love a ride! Give me a jingle if you can find the time ...Jeff 805-368-5857
jeff |
jeff |
Oct 31 2010, 10:26 AM
PeeGreen 914 |
Oct 31 2010, 11:02 AM
sixnotfour |
Oct 31 2010, 11:19 AM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Eric Fry is the autocrosser , my friend John Blonk did this one years ago, The lower door gap got huge, great look though.
Attached thumbnail(s) |
sixnotfour |
Oct 31 2010, 11:21 AM
Lo-Fi Version | Time is now: 16th May 2024 - 09:12 AM |
