Front bumper pad removal, how to? |
bob91403 |
Oct 5 2004, 10:24 AM
Senior Member Group: Members Posts: 618 Joined: 15-September 04 From: Los Angeles, CA Member No.: 2,763 |
QUOTE(ruddyboys @ Apr 21 2004, 05:29 PM) The front top pad was taken off by the PO and replaced with a homemade fiberglass one (and it looked it). I have the original pad and all the bolts were sered of on removal I assume. I was thinking of drilling straight thru the rubber and putting some carage bolts painted black thru to attach to bumper. It should look to bad, untill I can aford a good replacement Couldn't you drill the cut off posts and use some washers and sheet metal screws? Carriage bolts would look poor. (IMG:style_emoticons/default/wavey.gif) |
Root_Werks |
Oct 5 2004, 10:30 AM
Village Idiot Group: Members Posts: 8,338 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
To loosen the bolts for the bumper use a long extension with socket method. Someone already stated before, turn wheel left loosen bolts, turn wheen right loosen bolts, have something or someone catch bumper.
If you are tossing your old pad, just turn the little nuts. Either they will come off or break the little studs. Either way it will come off. I think there are 6 of them? <_< |
bob91403 |
Oct 5 2004, 10:32 AM
QUOTE(7391420 @ Oct 5 2004, 09:09 AM) -The nuts are so far inside of the wheel wells, I cant access them with any wrench or similar tool! -What would you all recommend for use to reach these? My socket set will reach but then there is no room to turn it! Maybe just a 15mm wrench and try to turn it a little at a time? I still dont think this will work because the space is so small? Help! -William, if your out there I'm west of boston, in Natick, let me know if you are around this weekend, maybe I take you up on your offer (of 6 months ago!) if I cant get the bumper off by sunday -Adam acox was right. (IMG:style_emoticons/default/agree.gif) Turn the wheels out to give you enough room to get at those bolts, should be easy. (IMG:style_emoticons/default/wavey.gif) |
Aaron Cox |
Oct 5 2004, 10:56 AM
use a 6 to 12" extension on a 3/8 ratchet. EASY. i used a 5 gallon bucket and a towel to hold mine.
7391420 |
Oct 5 2004, 11:43 AM
Member Group: Members Posts: 353 Joined: 6-August 03 From: boston, ma Member No.: 988 |
Thanks guys,
I'll give it a go over the next day or 2, I may need to get a better extention for my socket set, I think all i have is a 4 inch attachment, so I'll probably pick up a longer one! |
Lo-Fi Version | Time is now: 17th June 2024 - 01:20 AM |
