I Need a Battery Mount, ASAP |
seanery |
Apr 21 2004, 10:20 AM
I went out to put the optima in the 914. I put it in last fall but couldn't get it to fit exactly, so it was ziptied in from top and bottom. I'm doing a track day Sat/Sun and need a factory hold-down. I can't seem to locate mine DOH! Does anyone in the area have one?
thanks, sean |
dinomium |
Apr 21 2004, 10:31 AM
Git on a chair son, all the good stuff is goin over yer head! Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest |
I would call Triad and see if they can overnight you one of their Optima batt mounts...
http://www.triadwestperformance.com/images/914-eng.jpg |
Britain Smith |
Apr 21 2004, 11:09 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Actually...I have the perfect solution to the Optima battery hold-down issue.
You write Optima Customer Service and tell them you have on of their batteries and didn't get the mount to install your battery in your GM truck. You tell them you need the following: (IMG:http://www.optimabatteries.com/images/usingOptima/optimaThree.gif) OPTIMA® GROUP 34/78 The optional puck adapter is required for most GM installations where the side terminals are used.Position the puck against the center cylindar of the battery and bolt to the battery tray as shown. Here is the actual Optima page: Optima Battery Mounts Page. I did this and they sent me a couple. This mount bolt directly into the stock battery tray and works like a charm. -Britain |
GaroldShaffer |
Apr 21 2004, 01:03 PM
Sorry my friend I just check both parts cars and I don't have one. Call Bradholio Mayeur at 309-694-1797 I know he has em. He has about 6 parts cars behind his shop. Ask reakl nice and I am sure he would overnite it to you.
- Garold |
GaroldShaffer |
Apr 21 2004, 01:06 PM
Um, can we stop with the Bradholio stuff? its funny, when we are taking about our beloved Mr Roberts. (IMG:style_emoticons/default/laugh.gif)
Just for the record Mr. Mayeur is not a "holio" - Garold |
tod914 |
Apr 21 2004, 01:26 PM
Sean,
Just put the battery on it side and strap it down with a rubber bungie type cord. Got that from my local Auto Parts store. It has a metal "S" hook on each end. Easily secured to the bottom of the bat tray. Thats what I did with mine and it's rock solid. The batteries don't seem to fit well in the upright possition. |
JWest |
Apr 21 2004, 01:30 PM
QUOTE(Britain Smith @ Apr 21 2004, 11:09 AM) Actually...I have the perfect solution to the Optima battery hold-down issue. You write Optima Customer Service and tell them you have on of their batteries and didn't get the mount to install your battery in your GM truck. You tell them you need the following: (IMG:http://www.optimabatteries.com/images/usingOptima/optimaThree.gif) OPTIMA® GROUP 34/78 The optional puck adapter is required for most GM installations where the side terminals are used.Position the puck against the center cylindar of the battery and bolt to the battery tray as shown. Here is the actual Optima page: Optima Battery Mounts Page. I did this and they sent me a couple. This mount bolt directly into the stock battery tray and works like a charm. -Britain That's what I did - works great! |
GaroldShaffer |
Apr 21 2004, 01:34 PM
QUOTE Just put the battery on it side and strap it down with a rubber bungie type cord I don't think he will pass inspection for the track race he wants to run this weekend. (IMG:style_emoticons/default/confused24.gif) -Garold |
Apr 21 2004, 02:13 PM
Just go to your FLAPS and look. They'll have something that looks an awful lot like the stock clamp--a flattened triangle with a bolt through it.
--DD |
dinomium |
Apr 21 2004, 03:09 PM
Ok I just figured out FLAPS nuttin gitz by me!
(IMG:style_emoticons/default/headbang.gif) |
peridotian |
Apr 21 2004, 03:23 PM
Unregistered |
On the Bradholio thing, I used a hammer to pound in a Bradholio. Does this get converted as well, we will see.
seanery |
Apr 21 2004, 03:54 PM
Thanks for the advice guys. The optima mount is optimal, but I don't have time. I'm going to the Interstate Battery store in the morning (Optima dealer) hopefully they will have a mount for me.
Gint |
Apr 21 2004, 06:00 PM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Thanks for posting the Optima page with the bracket Britain! I have to order one of those.
seanery |
Apr 21 2004, 06:55 PM
So I was putting together a new toolbag for this weekend and found the mount in the old toolbag. I ground the edges off the case of the battery and all is good now.
Thanks again all. I'm gonna call and get a couple Optima GM mounts anyway. |
Brad Roberts |
Apr 22 2004, 01:36 AM
I HIGHLY recommend that everyone with an Optima GET one of these GM truck mounts. I have seen the stock 914 mount rip through the plastic bottom of the Optima. Not good. Someone showed me one of the mounts and I told them it was a GM truck mount (I drive one).. glad to know I was correct.
B |
seanery |
Apr 22 2004, 07:53 AM
45 seconds on the phone and they're on the way! (IMG:style_emoticons/default/smilie_pokal.gif)
Lo-Fi Version | Time is now: 17th May 2024 - 08:13 PM |
