engine trouble?, where to go to diagnose. |
DRPHIL914 |
Nov 2 2010, 09:03 AM
J (IMG:style_emoticons/default/confused24.gif) Bad news! (IMG:style_emoticons/default/headbang.gif)
saturday something gave out or blew out. Don't know what. At first it sounded like a exhaust leak louder on acceleration, letting of at first seemed ok then got louder. Im no engine mechanic but it I a valve and/or piston problem. Very specifically from the right side. I think rear cylinder. I am in beaufort sc so need to find someone close. I put new s.s.h.e. with triad exhaust on 1500 miles ago no problems it is not an exhaust leak. More of a clank (IMG:style_emoticons/default/confused24.gif) So it is a 75 2.0 with 130,000 d jet had been running great. Last 3tanks got 32-35 mpg! No leaks and oil use. I've had 1 year. If I have to take this apart I think I want something like. The 2056? Upgrade cam thing like jake rang does. So jake how much? For simple upgrade cam with valve.piston. head don't know yet but I thought it was running great. I do not drive it hard. Just became a d.d. to/ from work. I do not have the ability to lift high enough to drop the engine myself. any advice on where to take it? 5 horst from atlanta, 4 from charlolette n.c. Help! Phil |
dr914@autoatlanta.com |
Nov 2 2010, 09:07 AM
914 Guru Group: Members Posts: 7,857 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I will be in Hilton Head this weekend for the concours. Maybe I can drop by and listen to the engine, Phil.
J (IMG:style_emoticons/default/confused24.gif) Bad news! (IMG:style_emoticons/default/headbang.gif) saturday something gave out or blew out. Don't know what. At first it sounded like a exhaust leak louder on acceleration, letting of at first seemed ok then got louder. Im no engine mechanic but it I a valve and/or piston problem. Very specifically from the right side. I think rear cylinder. I am in beaufort sc so need to find someone close. I put new s.s.h.e. with triad exhaust on 1500 miles ago no problems it is not an exhaust leak. More of a clank (IMG:style_emoticons/default/confused24.gif) So it is a 75 2.0 with 130,000 d jet had been running great. Last 3tanks got 32-35 mpg! No leaks and oil use. I've had 1 year. If I have to take this apart I think I want something like. The 2056? Upgrade cam thing like jake rang does. So jake how much? For simple upgrade cam with valve.piston. head don't know yet but I thought it was running great. I do not drive it hard. Just became a d.d. to/ from work. I do not have the ability to lift high enough to drop the engine myself. any advice on where to take it? 5 horst from atlanta, 4 from charlolette n.c. Help! Phil |
7275914911 |
Nov 2 2010, 09:13 AM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
Did you 'blow' a plug out??
My #2 cylinder decided to eject it's plug yesterday. Sounded like I had a whole in the side of my engine from the top side. I did and it was the size of a spark plug!! Good Luck Ken |
DRPHIL914 |
Nov 2 2010, 09:18 AM
[quote name='dr914@autoatlanta.com' date='Nov 2 2010, 11:07 AM' post='1389822']
I will be in Hilton Head this weekend for the concours. Maybe I can drop by and listen to the engine, Phil. [quote name='Philip W.' post='1389821' date='Nov 2 2010, 08:03 AM'] J (IMG:style_emoticons/default/confused24.gif) Bad news! (IMG:style_emoticons/default/headbang.gif) saturday something gave out or blew out. Don't know what. At first it sounded like a exhaust leak louder on acceleration, letting of at first seemed ok then got louder. Im no engine mechanic but it I a valve and/or piston problem. Very specifically from the right side. I think rear cylinder. I am in beaufort sc so need to find someone close. I put new s.s.h.e. with triad exhaust on 1500 miles ago no problems it is not an exhaust leak. More of a clank (IMG:style_emoticons/default/confused24.gif) So it is a 75 2.0 with 130,000 d jet had been running great. Last 3tanks got 32-35 mpg! No leaks and oil use. I've had 1 year. If I have to take this apart I think I want something like. The 2056? Upgrade cam thing like jake rang does. So jake how much? For simple upgrade cam with valve.piston. head don't know yet but I thought it was running great. I do not drive it hard. Just became a d.d. to/ from work. I do not have the ability to lift high enough to drop the engine myself. any advice on where to take it? 5 horst from atlanta, 4 from charlolette n.c. George, Wow that would be great, but I actually have to be in florida saturday and sunday ( I ocasionally teach college and post. Grad sports chiropractic classes) so depends on when u are coming and leaving. Im in beaufort but would put it on a car hauled and bring it over just to have the chance to meet you, and get your opinion on this. Phil [/quote] |
Cap'n Krusty |
Right side? I suspect valve/seat/piston issues with #3 cylinder.
The Cap'n |
DRPHIL914 |
Nov 2 2010, 09:20 AM
B
Did you 'blow' a plug out?? My #2 cylinder decided to eject it's plug yesterday. Sounded like I had a whole in the side of my engine from the top side. I did and it was the size of a spark plug!! Good Luck Ken (IMG:style_emoticons/default/beer3.gif) Ken, I will.look closer may be? It was not too loud at first got louder then lost some power, ill check tonight. |
realred914 |
Nov 2 2010, 09:34 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
A standard floor jack and some medium sized stands should get the car high enough in the air to be able to remove the motor, been doing it that way for a long long time.
Lo-Fi Version | Time is now: 15th May 2024 - 10:31 PM |
