Engine Mounts/Suspension arms, Are all model years interchangeable? |
saigon71 |
Nov 2 2010, 08:33 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Back to work on the teener - 74 D-jet. Car is braced and a very rusty right longitudinal has been cut out of the hell hole. I am in the market for the outer suspension arm and the right side engine bar mount (the entire assembly, not just the U piece at the bottom).
My question is, are these parts the same throughout all model years? Pics of parts needed attached. Thanks, Bob |
Krieger |
Nov 2 2010, 09:28 PM
Advanced Member Group: Members Posts: 4,711 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I think all 4 cylinder trailing arms are the same. When you say "right side engine bar mount" if it is it a U shaped channel 3" long or so it is the later style. Early cars had a rubber mount similar to the rubber trans mount.
dr914@autoatlanta.com |
Nov 3 2010, 09:04 AM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes all fours were the same.
Back to work on the teener - 74 D-jet. Car is braced and a very rusty right longitudinal has been cut out of the hell hole. I am in the market for the outer suspension arm and the right side engine bar mount. My question is, are these parts the same throughout all model years? Thanks, Bob |
saigon71 |
Nov 3 2010, 09:49 AM
yes all fours were the same. Back to work on the teener - 74 D-jet. Car is braced and a very rusty right longitudinal has been cut out of the hell hole. I am in the market for the outer suspension arm and the right side engine bar mount. My question is, are these parts the same throughout all model years? Thanks, Bob Thanks George - appreciate the info. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:46 PM |
