mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,935 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
Even a few years ago, I could go to Autozone and they would have basic
studs even metric, in the back. Now unless it's a part number, not. And, what is the official name of these rubberized clamp things? The ~30 year old guy behind the counter thought I was crazy. Attached image(s) ![]() |
silver74insocal |
Senior Member ![]() ![]() ![]() Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California ![]() |
http://www.summitracing.com/parts/SUM-G1882/
you just gotta find the size you are looking for but this should help (IMG:style_emoticons/default/beerchug.gif) Dave |
bobhasissues |
seemingly endless issues with my 914 ![]() ![]() Group: Members Posts: 218 Joined: 13-February 07 From: Chicagoland Member No.: 7,532 Region Association: None ![]() |
http://www.mcmaster.com/#pipe-routing-clamps/=9lwcs6
Try McMaster Carr, not sure the above is an active link, look up loom clamps. Regarding the uselessness of a FLAPS counter person, I went to a PepBoys and asked if they had NGK BP5ES spark plugs. The guy's first response was what kind of car are they for? |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Adel clamps.
There is a bolt and nut section in the store. It is small and on little rotating racks typically. You are right about the lack of knowledge the parts monkies have. NAPA is even becoming a losing fight (IMG:style_emoticons/default/dry.gif) |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
Adel clamps. Yes. Originally an aircraft part, which is why the counter guy didn't know it. Like a lot of useful aircraft parts, race car guys used to use them in part because they are strong and light, but mostly because they [aircraft parts] were available CHEAP due to overruns and salvage in the industry. Not for nothing did the use of braided steel hose start in the literal back yard of Douglas Aircraft and Northrup... QUOTE NAPA is even becoming a losing fight No Actual Parts Available... They are my last resort. Some of them do try to help, because after all, they want to sell you stuff, but they are clueless. I was shopping for a new V-belt one day after I'd transplanted a newer engine into an older car, leaving stuff like the power steering pump behind. They had no idea that the belt part number contains the length and width... They did keep asking 'What's it for?' and I kept saying - 'It wouldn't help...' |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,186 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I was rebuilding some calipers and ask for some brake cylinder paste. They (FLAPS) thought I was crazy.
mskala |
There is a bolt and nut section in the store. It is small and on little rotating racks typically. I've used the parts off the racks before. It sucks, though, because even if I figure I'll just make my own stud by cutting the end off a bolt, they never have full threaded bolts (IMG:style_emoticons/default/mad.gif) |
mskala |
Thanks all. I just hate trying to find something and then mail-ordering a 99 cent
piece. Which reminds me, I have 48 extra early ball-joint clamp bolts because I couldn't find the right hardness, bought a box of 50 from somewhere. |
Tom |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None ![]() |
Electrical/electronics parts store should have these and ones similar in plastic. Always refered to them as cable/wire clamps.
Tom |
Dr Evil |
I get long, odd sized/threaded allthread from Fastenall. See if there is one near you.
geniusanthony |
Its a brand new "Chrome-sicle" ![]() ![]() ![]() Group: Members Posts: 517 Joined: 12-December 05 From: Alexandria,VA Member No.: 5,266 Region Association: MidAtlantic Region ![]() |
Seems like there is always a Grainger nearby too. The guys there are alot more helpful than say your average parts store worker. And yeah, the "what car is it for" line for standardized parts drives me up the wall.
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,185 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
I agree with your assessment of most FLAPS these days. They prescribe to what I call the "spreadsheet mentality" which means they only stock the top 50-80% of what sells a lot.
The little stuff like what you're trying to find is gone from most FLAPS because it is not a high runner. Same is true of big chain home supply stores. My local ACE hardware store still sells nuts and bolts by the piece and not 5 pieces packaged together for $1.50. They even sell metric sizes too. |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,096 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
The ACE hardware by me has by far the best selection of nuts and bolts I have found locally since Metric Supply closed up. It may take me awhile to wade through all the choices and pick the hardware I want. I am not going comment on the FLAPS since the company I work for is owned by a major FLAPS chain. Jim |
realred914 |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None ![]() |
global metric is good source of metric stuff.
hardwares stores are good source, as are speed shops, some auto store still stock the good stuff, but is is a dying thing, most folks donot do real repair work on there cars anymore, so the auto stores now seem to stock mostly dressup junk, floor matts, blue headlights kits, and them funny smelling pine trees. |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
You can get Adel clamps at Home Depot.
I bought a bag through McMaster that are for the 1/2 OD and are made from stainless and silicone (for higher temps). You can have some if you want... |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,735 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Like the Doc said, Adel clamps: http://www.aircraftspruce.com/catalog/appages/0400920.php
Elliot Cannon |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None ![]() ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) My Son (the bike mechanic) used to call them "P" clamps. He knows to ask for adel clamps now. (IMG:style_emoticons/default/laugh.gif) |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
My ace is great for that stuff as well. As far as FLAPS, the lady thought I was crazy giving her the part number for the NGK plugs, but she found them after I said look on the box (IMG:style_emoticons/default/blink.gif)
dlestep |
I am smilin'... ![]() ![]() ![]() Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States ![]() |
...in the recent past, I went to most of the automotive parts stores in my area looking for assembly lube and every parts counter dweeb asked, "what is that...?"
Did I fall asleep for a century and wake up in retard land... |
Lo-Fi Version | Time is now: 6th July 2025 - 01:39 AM |
