2nd gear grind |
2nd gear grind |
mipstien |
Nov 11 2010, 08:29 AM
Member Group: Members Posts: 261 Joined: 6-April 10 From: Maryville, TN Member No.: 11,576 Region Association: South East States |
I have a slight grind when going into second gear. if i let off the gas for maybe 2 or 3 seconds after first then it doesn't grind. it never jumps out of gear though. it did just start this around 100 miles ago.
is there some adjustments i need to look into? |
76-914 |
Nov 11 2010, 08:33 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I've only rebuilt one 901 (that makes me an expert (IMG:style_emoticons/default/lol-2.gif) ) but IMHO you have a syncro thats kaput. If it isn't jumping out of gear then the dog teeth are probably ok.
pcar916 |
Nov 11 2010, 08:47 AM
If...
1. The clutch is adjusted properly and 2. your fluid level is good and 3. the fluid is in good shape and 4. your shift linkage bushings are all good, I'd bet on the synchro. It's also well known that double-clutching and matching revs both up and down-shifting is very good for out transaxles. |
realred914 |
Nov 11 2010, 09:14 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
slow shifting as long as you can will keep it running.
believe it or not i solved a probelm like tis by switching to redline sythetic in my tranny, bought a 914, shifted poor like you have, put in new regular oil, no change, tried redline next, and the problem went away, 80k miles later still working (I bought the car cheap cuase the owner thought the tranny was shot) nurse it as much as you can with slow shifting (a benifit of a tail shifter is slow shifting!!!) try the snake oil fix of red line, it might help, else tiem to rebuild when it gets too bad. have fun |
Lo-Fi Version | Time is now: 15th May 2024 - 12:56 AM |
