#1 & 2 plugs fowling |
biker bob |
Nov 11 2010, 09:17 AM
Member Group: Members Posts: 53 Joined: 25-March 09 From: Eureks Springs Ar. Member No.: 10,200 Region Association: Southwest Region |
Need help tuning carbs. I have very little experience with dual carb adjusting. 72 2.0L turn key engine. No issues with valves, rings or compression. Had some issues with the EMPI 44's that I believe are now solved. Comp-fire ignition installed and using Bosche WR7CC+ plugs. I have followed carb tuning instructions however I must be missing something. With new plugs the car runs great for about 40 miles then # 1&2 plugs begin to fowl out almost completely black and engine loses power. No smoke coming from the exhaust. I replace the plugs and it runs great for another 40 miles. What am I doing wrong? Any suggestions appricated. Thanks Bob
realred914 |
Nov 11 2010, 10:40 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
Need help tuning carbs. I have very little experience with dual carb adjusting. 72 2.0L turn key engine. No issues with valves, rings or compression. Had some issues with the EMPI 44's that I believe are now solved. Comp-fire ignition installed and using Bosche WR7CC+ plugs. I have followed carb tuning instructions however I must be missing something. With new plugs the car runs great for about 40 miles then # 1&2 plugs begin to fowl out almost completely black and engine loses power. No smoke coming from the exhaust. I replace the plugs and it runs great for another 40 miles. What am I doing wrong? Any suggestions appricated. Thanks Bob fuel level in bowls the same? maybe the float needs adjustment? make sure they are the same, and correct. after that look for cleanliness and adjustment of the carbs. and intake leaks (may the 'good one' is running rich too, but is masked by an intake leak???) go thru these basics first thy try to adjust again. if all else fails, try a compression test just to make sure your not all sooty couse of failed rings. PS also make sure the valves are adjusted correctly on both sides, and test you spark wires too. if either of these is wrong, carbs adjusting wont fix it. if this is a new motor, could be rings not seated yet? and needs more break in period? do you smell strong gas smell from tail pipe? good luck (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/bye1.gif) |
biker bob |
Nov 11 2010, 12:09 PM
Carbs are new and adjustments seem to be working. No flooding. The engine is new (1700 miles) with hydraulic lifters. Compression tested according to specs. How long does normally take to seat the rings?
How do you test the plug wires? No smoke or the smell of gas coming from the tail pipe. |
Lo-Fi Version | Time is now: 13th May 2024 - 07:08 PM |
