cam shaft selection, 2056 cc D-jet |
realred914 |
Nov 11 2010, 10:24 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
looking for advice on cam shaft selection for a 2056 cc motor that will be running the stock D-jet injection system.
sicne I will have big bore cylinders is there any recommended cam grind other than the stock one that will work well? also is there any other goodies i should consider to go along with the big bore pistons? thanks in advance (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/icon_bump.gif) (IMG:style_emoticons/default/icon_bump.gif) |
blitZ |
Nov 11 2010, 10:51 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I have Jakes 9550 cam in my dJet 2056 and it works very well. Nice hp increase and cooler head temperatures.
Root_Werks |
Nov 11 2010, 11:03 AM
Village Idiot Group: Members Posts: 8,319 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I have Jakes 9550 cam in my dJet 2056 and it works very well. Nice hp increase and cooler head temperatures. (IMG:style_emoticons/default/agree.gif) Many are running Jakes cam and I plan on doing the same when my engine comes out again. |
tradisrad |
Nov 11 2010, 11:08 AM
yep, the raby cam is nice in my engine. You will need to have the MPS tweaked by someone or install a O2 and do the tuning your self.
sean_v8_914 |
Nov 11 2010, 11:37 AM
10jreen currently running a jake cam'd 2056 w d jet and AA 96mm. we sure flog that poor thing. if it died tomorrow it would be an honorable death
Jake Raby |
Nov 11 2010, 11:48 AM
My 9550 is a specific grind for stock injection, but that doesn't mean that its what I'll choose for you if you decide to buy one of my cam packages.
I have the 9560, 9590 and 9595 that may also be applicable based on your CR, elevation, intended RPM range, head work and overall goals for the engine. The 9550 is a nice cam and the most popular, but its not a one size fits all for every stock FI application. |
Root_Werks |
Nov 11 2010, 01:38 PM
My 9550 is a specific grind for stock injection, but that doesn't mean that its what I'll choose for you if you decide to buy one of my cam packages. I have the 9560, 9590 and 9595 that may also be applicable based on your CR, elevation, intended RPM range, head work and overall goals for the engine. The 9550 is a nice cam and the most popular, but its not a one size fits all for every stock FI application. Not to get too side tracked Jake, but I plan on taking my 914 engine out this winter just for this upgrade. I'll use stock heads, with 96's, probably 8.5-9.0:1 with L-Jet (Not D-Jet). Which one of your cams would be best? Sea level driving. (IMG:style_emoticons/default/driving.gif) |
realred914 |
Nov 12 2010, 11:23 AM
My 9550 is a specific grind for stock injection, but that doesn't mean that its what I'll choose for you if you decide to buy one of my cam packages. I have the 9560, 9590 and 9595 that may also be applicable based on your CR, elevation, intended RPM range, head work and overall goals for the engine. The 9550 is a nice cam and the most popular, but its not a one size fits all for every stock FI application. jake i sent you the form filled out you emailed me, still i am open to valve and compression selection as the motor is still in planning stage so no new componnets have been bought yet. looking forward to your suggestions on cam and what you recomomend to run with it. thanks! |
Jake Raby |
Nov 12 2010, 07:11 PM
doesn't quite work that way..
I'll need you to tell me what you have for CR, valve sizes and other head specs.. I can't make a selection without this.. I also won't recommend settings because I then become responsible for your engine design and I can't do that.. You are the designer and builder and those things are up to you to research, learn and apply. I have engine kits that feature my full design. |
Lo-Fi Version | Time is now: 14th May 2024 - 04:39 PM |
