Which suspension combo, kits or pieces.... |
speed metal army |
Nov 13 2010, 12:46 AM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Im looking for the best kit or combo of individual components for my suspension.Ive got a '76 2.0.
Its for the street only,but would like to have quailty handling under aggressive conditions. Any suggestions of full kits,or individual shocks/struts/springs etc. that work for you? Thanks |
Derek Seymour |
Nov 13 2010, 01:36 AM
Member Group: Members Posts: 394 Joined: 10-March 09 From: Yucaipa Member No.: 10,151 Region Association: Southern California |
I found this to be very helpful for choosing the torsion/ spring rates
914World.com As far as brands go I went with: Bilstein HD shocks on all fours. Weltmeister springs in the rear. Sway-A-Way torsion bars up front. |
dr914@autoatlanta.com |
Nov 13 2010, 09:07 AM
914 Guru Group: Members Posts: 7,856 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
An easy inexpensive way to get great handling is to install a set of high speed rated 195 65 15 tires with stiff sidewall, 100 lb springs, and bilstein shocks. You will be quite impressed with the improvement and still have a very drivable 914
Im looking for the best kit or combo of individual components for my suspension.Ive got a '76 2.0. Its for the street only,but would like to have quailty handling under aggressive conditions. Any suggestions of full kits,or individual shocks/struts/springs etc. that work for you? Thanks |
bmtrnavsky |
Nov 13 2010, 10:42 AM
Member Group: Members Posts: 355 Joined: 20-October 07 From: Longview, TX Member No.: 8,245 Region Association: Southwest Region |
An easy inexpensive way to get great handling is to install a set of high speed rated 195 65 15 tires with stiff sidewall, 100 lb springs, and bilstein shocks. You will be quite impressed with the improvement and still have a very drivable 914 Im looking for the best kit or combo of individual components for my suspension.Ive got a '76 2.0. Its for the street only,but would like to have quailty handling under aggressive conditions. Any suggestions of full kits,or individual shocks/struts/springs etc. that work for you? Thanks George talked me into that setup for my 73 2.0 and I couldn't be more happy with it. The car came alive. It set it about 1 1/2 inches lower and made the car much more responsive to steering input. My suspension was fairly shot so anything would have been better, but this is as stiff as I would ever go considering I mostly use mine for summer time commuting and road trips. |
speed metal army |
Nov 13 2010, 11:31 AM
An easy inexpensive way to get great handling is to install a set of high speed rated 195 65 15 tires with stiff sidewall, 100 lb springs, and bilstein shocks. You will be quite impressed with the improvement and still have a very drivable 914 Im looking for the best kit or combo of individual components for my suspension.Ive got a '76 2.0. Its for the street only,but would like to have quailty handling under aggressive conditions. Any suggestions of full kits,or individual shocks/struts/springs etc. that work for you? Thanks Got the tires already,so I guess I'll seek out some Springs/shocks. Thanks! |
Lo-Fi Version | Time is now: 14th May 2024 - 05:56 PM |
