whew.... I didn't even have to email Jake, to bail me out this weekend |
brant |
Nov 14 2010, 11:36 PM
Spent another day and a half doing assembly.
Its going to be years at the rate I'm going but measuring (to cut) pushrod tubes takes a long time guess If I was smarter I'd be quicker... 4 down.. 4 to go the big time killer was in building a bracket for the dial indicator they got faster as I went. ended up with really good lift numbers on my 9590 cam and .30 shims under the rockers. (wish I had bought shims before starting the project... had to run to napa and buy shim material, then cut/trim/and drill it to use it...) finally starting to feel like a motor again Thanks for the great write up article jake... I ended up measuring all 4 independently 1 and 2 intakes came out only .01 apart, but exhausts a little more. Attached thumbnail(s) Attached image(s) |
TheCabinetmaker |
Nov 15 2010, 06:22 AM
Is this for your race car? I thought you had a six.
Jake Raby |
Nov 15 2010, 08:55 AM
Good going..
BUT the rocker shaft end caps are installed upside down. :-) |
RJMII |
Nov 15 2010, 10:44 AM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
brant |
Nov 15 2010, 10:47 AM
its going to be a street motor (Djet)
and resurrect a car I've had for way too many years... my first 914, that I got as a teen. car has been sitting in a storage building for way too long and needs to be back on the road! Jake, ha... I didn't even realize that. Bet I would of had a hard time getting the pushrod springs on. Thank you. I'll flip them Thanks again for the great article. I wanted to get all of them done at once, per your article, but ran out of time. I feel good about the process though and the other 4 should be cake. brant |
bandjoey |
Nov 15 2010, 10:50 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I think the cut out for the push rod spring retainer goes 180 degrees opposite of where you have it. Experts to chime in?
Bleyseng |
Nov 15 2010, 11:16 AM
realred914 |
Nov 15 2010, 12:35 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
its going to be a street motor (Djet) and resurrect a car I've had for way too many years... my first 914, that I got as a teen. car has been sitting in a storage building for way too long and needs to be back on the road! Jake, ha... I didn't even realize that. Bet I would of had a hard time getting the pushrod springs on. Thank you. I'll flip them Thanks again for the great article. I wanted to get all of them done at once, per your article, but ran out of time. I feel good about the process though and the other 4 should be cake. brant Hi Brant: seems like you are doing what i like to do, build a 2056 cc motor with d-jet. just wondering all teh specifications on your motor build. also what article is it you refer to ? can you post same or link it? I am in process of deciding on parts to buy for my motor. please let me know what components you are using and issues you may have run into. thanks |
brant |
Nov 15 2010, 01:02 PM
Hi Brant: seems like you are doing what i like to do, build a 2056 cc motor with d-jet. just wondering all teh specifications on your motor build. also what article is it you refer to ? can you post same or link it? I am in process of deciding on parts to buy for my motor. please let me know what components you are using and issues you may have run into. thanks I'm actually building a 2.0 displacement honestly, I'm re-using U.S. piston and cylinders that were in spec, with new rings. I honed them and re-ringed them. They are not the high compression piston and they are only 94's. so the motor is pretty mild. Its got a melling oil pump that I worked over and has great tolerances. A Jake Raby cam kit (with all of the kit updates, and pushrods) A stock crank that is std/std and was micropolished. A line bored case that is now 2 over. (Believe it or not, this was a running motor and had never been line bored. Upon line boring it was found to be so far off that it actually had to go 2 over... I'm not trusting cases these days.... ) I had the heads rebuild stock by a very good builder They are now cut 1x. (same guy that does my race motors) Same race builder rebuilt/resized/rebushed the rods also. I'm sure I'm forgetting something.. but basically a stock 2.0 motor with stock Djet. Just the cam upgrades and a lot of attention to detail, a lightweight flywheel and set of SSI's nothing special about the motor. Just trying to get it right! No issues at this point. Bearings were kinda hard-ish to find. I'm learning alot about things I thought I already knew well enough. There is a lot of detail to learn, and it makes me respect (even more) the good builders out there. The article is just Jakes pushrod tube measurement article. Sorry I don't have the link on me at the moment, but its readily available. To be thourough, I read Van's, and a couple of others articles too. Plus I called my race builder for a 30 minute consultation and question period! (Thanks AJ!) brant |
Lo-Fi Version | Time is now: 15th May 2024 - 08:14 AM |
