QUOTE(realred914 @ Nov 15 2010, 11:35 AM)
Hi Brant: seems like you are doing what i like to do, build a 2056 cc motor with d-jet.
just wondering all teh specifications on your motor build. also what article is it you refer to ? can you post same or link it?
I am in process of deciding on parts to buy for my motor.
please let me know what components you are using and issues you may have run into.
thanks
I'm actually building a 2.0 displacement
honestly, I'm re-using U.S. piston and cylinders that were in spec, with new rings. I honed them and re-ringed them. They are not the high compression piston and they are only 94's.
so the motor is pretty mild. Its got a melling oil pump that I worked over and has great tolerances. A Jake Raby cam kit (with all of the kit updates, and pushrods) A stock crank that is std/std and was micropolished. A line bored case that is now 2 over. (Believe it or not, this was a running motor and had never been line bored. Upon line boring it was found to be so far off that it actually had to go 2 over... I'm not trusting cases these days.... )
I had the heads rebuild stock by a very good builder They are now cut 1x.
(same guy that does my race motors)
Same race builder rebuilt/resized/rebushed the rods also.
I'm sure I'm forgetting something.. but basically a stock 2.0 motor with stock Djet. Just the cam upgrades and a lot of attention to detail, a lightweight flywheel and set of SSI's
nothing special about the motor. Just trying to get it right!
No issues at this point. Bearings were kinda hard-ish to find. I'm learning alot about things I thought I already knew well enough. There is a lot of detail to learn, and it makes me respect (even more) the good builders out there.
The article is just Jakes pushrod tube measurement article. Sorry I don't have the link on me at the moment, but its readily available. To be thourough, I read Van's, and a couple of others articles too. Plus I called my race builder for a 30 minute consultation and question period! (Thanks AJ!)
brant
