wheels |
wheels |
matteyp |
Nov 14 2010, 11:52 PM
Nothing a little JB Weld can't fix... Group: Members Posts: 263 Joined: 8-June 09 From: WA Member No.: 10,450 Region Association: Pacific Northwest |
Hey guys, I was looking at some wheels from american eagle for my 914. Has anyone ran these wheels? They look like they would fit. I just have the standard 4x130 bolt pattern. These look pretty nice and I was just wondering if anyone knew anything about them. Also cant really find any prices, has anyone bought these? Heres the link
http://aewheel.com/wheels.cfm?id=5 Thanks guys matt |
Andyrew |
Nov 15 2010, 01:54 AM
Make sure they are 914 offset not VW offset... Do a search for offset.. I havent touched stock wheels in so long I forgot what it is..
matteyp |
Nov 15 2010, 02:30 AM
hmmm well i just dont know enough about changing everything to go with anything else. 5 bolt or different offsets or what will fit and what wont. Any info anyone can give is appreciated. thanks
johannes |
Nov 15 2010, 04:05 AM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
Those are heavy, they will barely fit because they have VW offset and your choice of rubber will be more than limited.
bandjoey |
Nov 15 2010, 12:48 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Had a set and they wouldn't fit without rolling out the finders. Good looking wheels and I see them on 914 pictutes. Body work required.
jsaum |
Nov 15 2010, 12:56 PM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
AA has these rims listed in their catalog page 75 set of four for $439.94 #B710-5530 call them and ask about the 914 offset.
Jsaum |
racerbvd |
Nov 15 2010, 01:17 PM
Advanced Member Group: Members Posts: 2,368 Joined: 3-February 03 From: Sunny FL. Member No.: 226 Region Association: None |
Pick up a Hot WVs magazine, lots of ads for them in there, much better prices too, just make sure & order the 914 offset..
carr914 |
Nov 15 2010, 06:28 PM
Racer from Birth Group: Members Posts: 118,580 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Pass - wait on a pair of 4-lug Fuchs or go 5-lug
racerbvd |
Nov 15 2010, 09:49 PM
Pass - wait on a pair of 4-lug Fuchs or go 5-lug Speaking of 4 lug Fuchs, did you sell your's?? (IMG:style_emoticons/default/beer.gif) |
sixnotfour |
Nov 15 2010, 09:56 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
geniusanthony |
Nov 15 2010, 11:29 PM
Its a brand new "Chrome-sicle" Group: Members Posts: 517 Joined: 12-December 05 From: Alexandria,VA Member No.: 5,266 Region Association: MidAtlantic Region |
this may help understand offset some
Attached thumbnail(s) |
geniusanthony |
Nov 15 2010, 11:32 PM
6 x 16 dimensions fit no problem all the way around, a 7 x 16 will fit in the rear with rolling of the lip but its tight, real tight. Depends on camber setting and ride height and variables such as that. If you don't wanna mess with metalwork than the 6 x 16 size is an easy option.
damesandhotrods |
Nov 16 2010, 12:29 AM
Senior Member Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
Coming from the VW world, the right off set for those American Eagle wheels hasn’t been made for decades. If you find an old set of EMPI’s you’ll be fighting Karmann Ghia and Type 3 owners over them. Those wheels are intended for Beetles. I’ve seen a couple of 914’s with them, but stock height and very tight fitting. Hot VW’s ads are full of them, and The Samba.com is a good source for used.
dlkawashima |
Nov 16 2010, 12:45 AM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
Bug houses like cip1 or kustom1warehouse carry that wheel. JC Whitney also carries it .... in their classic VW section.
nsr-jamie |
Nov 16 2010, 04:16 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
One of my friend has those wheels on his 914 in gold with the polished lip, not sure of the offset, he runs 185/60 tires on them but they fit fine on the back, anything more than that might be risky. They are nice looking wheels though...they looked good on my friends car which was black.
carr914 |
Nov 16 2010, 05:09 AM
Pass - wait on a pair of 4-lug Fuchs or go 5-lug Speaking of 4 lug Fuchs, did you sell your's?? (IMG:style_emoticons/default/beer.gif) Yes, I'm shipping them today |
swl |
Nov 16 2010, 06:58 AM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Cips has a new supplier for empi style wheels. http://www2.cip1.com/ProductDetails.asp?Pr...32%2DLIT413%2DC
It is early and thee caffiene hasn't kicked in so see if this logic is correct. They are 4" backspace 101.6mm. Using tony's diagram that says the wheel will stick out 10 mm farther than stock. So if a stock wheel will support a 205 tire the max for 4" backspace would be a 195. Sound right? |
dlkawashima |
Nov 16 2010, 06:43 PM
Cips has a new supplier for empi style wheels. http://www2.cip1.com/ProductDetails.asp?Pr...32%2DLIT413%2DC It is early and thee caffiene hasn't kicked in so see if this logic is correct. They are 4" backspace 101.6mm. Using tony's diagram that says the wheel will stick out 10 mm farther than stock. So if a stock wheel will support a 205 tire the max for 4" backspace would be a 195. Sound right? Those are the Fuchs 2.0 clones. At kustom1warehouse, those wheels are listed as having a backspacing of 4-9/16". |
Drums66 |
Nov 16 2010, 06:58 PM
Those are heavy, they will barely fit because they have VW offset and your choice of rubber will be more than limited. ...Yes they are heavy...... (IMG:style_emoticons/default/poke.gif) BTW...put a v-8 in there to spin them! (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/bye1.gif) (maybe mini-lites) |
swl |
Nov 17 2010, 08:50 PM
Cips has a new supplier for empi style wheels. http://www2.cip1.com/ProductDetails.asp?Pr...32%2DLIT413%2DC It is early and thee caffiene hasn't kicked in so see if this logic is correct. They are 4" backspace 101.6mm. Using tony's diagram that says the wheel will stick out 10 mm farther than stock. So if a stock wheel will support a 205 tire the max for 4" backspace would be a 195. Sound right? Those are the Fuchs 2.0 clones. At kustom1warehouse, those wheels are listed as having a backspacing of 4-9/16". Yep - I guess it was too early to be at the keyboard. Here are the empi's. Still listed at 4". http://www2.cip1.com/SearchResults.asp?Search=32-E28 No listing on the weight though. |
Lo-Fi Version | Time is now: 14th May 2024 - 03:12 AM |
