Spark at coil |
Spark at coil |
ruddyboys |
Apr 22 2004, 06:46 PM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
Checking why car won't start, pulled the wire from the condenser and when I tried to place it back on the coil i got sparks. Could the condender be bad or something grounding in the dizzy?
TheCabinetmaker |
Apr 22 2004, 06:48 PM
which side of the coil ya plugging it into?
ruddyboys |
Apr 22 2004, 06:58 PM
Condeser, and tack -
ignition + |
TheCabinetmaker |
Apr 22 2004, 07:17 PM
Large black wire goes to + side of coil. Condensor and tach goes to the - side of coil
TheCabinetmaker |
Apr 22 2004, 07:19 PM
opps, I read your last post wrong. My bad.
TheCabinetmaker |
Apr 22 2004, 07:20 PM
Have ya checked the points?
ruddyboys |
Apr 22 2004, 07:24 PM
I haven't checked gap, they do separate
TheCabinetmaker |
Apr 22 2004, 07:30 PM
Point gap shouldn't matter as long as they are not burned together. If you hook up the consensor wire and it starts to melt, or smoke comes from the diz, ya got something hooked up wrong, or a dead short.
ruddyboys |
Apr 22 2004, 07:34 PM
Nothing melts or smokes, car just wont start. cranck fine just wont start. That when I tried diconnecting the condenser wire. When I put it back to the - terminal I got the spark at the terminal. If there is a ground would it be in the dizzy?
TheCabinetmaker |
Apr 22 2004, 07:40 PM
It should not spark when plugging it in. Do you have spark from the coil wire with everything connected?
ruddyboys |
Apr 22 2004, 07:44 PM
I checked the wirt from pulg 1, while cranking I got a very week looking spark
TheCabinetmaker |
Apr 22 2004, 08:28 PM
Ok, go check the point gap, or use a dwell meter. Too much or not enough dwell will cause a no start condition
Lo-Fi Version | Time is now: 17th May 2024 - 07:31 PM |
