Gasoline Heaters, 914's and buses |
Randal |
Nov 20 2010, 10:39 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Did 914's and buses have gasoline heaters and if so where were they and how did they work? Love to see a picture if anyone has one. |
Mueller |
Jan 2 2018, 02:34 PM
Update on this heater I've had for years!
No go with the 12vdc to 24vdc converter, it claims it is 10 amps yet it will barely run the fan. I did get the heater to fire up using 2 12vdc car batteries in series, however after 5 minute run time it shut off. I smoked quite a bit out of the exhaust, could be due to age and from someone previously running a different fuel? (I used gas) Decided not worth it and will be in the market for real heat exchangers to replace my patched up no name header. |
mepstein |
Jan 2 2018, 03:07 PM
914-6 GT in waiting Group: Members Posts: 19,275 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Update on this heater I've had for years! No go with the 12vdc to 24vdc converter, it claims it is 10 amps yet it will barely run the fan. I did get the heater to fire up using 2 12vdc car batteries in series, however after 5 minute run time it shut off. I smoked quite a bit out of the exhaust, could be due to age and from someone previously running a different fuel? (I used gas) Decided not worth it and will be in the market for real heat exchangers to replace my patched up no name header. HE’s are the way to go. Bolt up quickly and throw tons of heat. Do you need 1.7’s or 2.0 |
Mueller |
Jan 2 2018, 03:13 PM
Update on this heater I've had for years! No go with the 12vdc to 24vdc converter, it claims it is 10 amps yet it will barely run the fan. I did get the heater to fire up using 2 12vdc car batteries in series, however after 5 minute run time it shut off. I smoked quite a bit out of the exhaust, could be due to age and from someone previously running a different fuel? (I used gas) Decided not worth it and will be in the market for real heat exchangers to replace my patched up no name header. HE’s are the way to go. Bolt up quickly and throw tons of heat. Do you need 1.7’s or 2.0 1.8 with a slightly hotter cam. |
Lo-Fi Version | Time is now: 19th May 2024 - 09:55 AM |
