Gasoline Heaters, 914's and buses |
Randal |
Nov 20 2010, 10:39 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Did 914's and buses have gasoline heaters and if so where were they and how did they work? Love to see a picture if anyone has one. |
r_towle |
Nov 29 2013, 04:24 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Foley has a heater box that fits over one side and provides some heat, not sure how much.
Why couldn't you fabricate a heater box that fits over the European headers. It's just a box with two holes for the large air hoses to push air in and out. Might be a wierd jigsaw puzzle, but using two pieces screwed together and capturing some of the header pipes should do the trick, then you can unscrew it to service the headers... It does not take much to heat up a 914 cabin. |
Mark Henry |
Nov 30 2013, 09:15 AM
Foley has a heater box that fits over one side and provides some heat, not sure how much. Why couldn't you fabricate a heater box that fits over the European headers. It's just a box with two holes for the large air hoses to push air in and out. Might be a wierd jigsaw puzzle, but using two pieces screwed together and capturing some of the header pipes should do the trick, then you can unscrew it to service the headers... It does not take much to heat up a 914 cabin. Perry K will pimp slap you for that idea (IMG:style_emoticons/default/biggrin.gif) I've been thinking of doing the same on my /6, putting a box affair around the MSDS headers. I would agree with Perry it would be a bad idea as the mild steel tubes could rust out, but then the majority of us will never drive in the snow and salt . If you were to try this I would for sure invest in this. http://www.aircraftspruce.ca/catalog/pspag...clickkey=134504 (IMG:http://www.914world.com/bbs2/uploads_offsite/www.aircraftspruce.ca-26-1385824632.1.jpg) |
Lo-Fi Version | Time is now: 7th May 2024 - 08:23 AM |
