Gasoline Heaters, 914's and buses |
Randal |
Nov 20 2010, 10:39 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Did 914's and buses have gasoline heaters and if so where were they and how did they work? Love to see a picture if anyone has one. |
GeorgeRud |
Jan 2 2018, 05:06 PM
I also purchased the same heater as Mueller, and glad to see that it could fit in the car. Perhaps using two 12-24 volt converters could provide adequate wattage to run the fan. I also have a used B1L Eberspacherthat I was going to use with my headers, but eventually found some good heat exchangers so went that route. I remember that gas heaters do work quite well in heating the interior, but they’re not the easiest thing to fit safely.
Mueller |
Jan 2 2018, 06:07 PM
I also purchased the same heater as Mueller, and glad to see that it could fit in the car. Perhaps using two 12-24 volt converters could provide adequate wattage to run the fan. I also have a used B1L Eberspacherthat I was going to use with my headers, but eventually found some good heat exchangers so went that route. I remember that gas heaters do work quite well in heating the interior, but they’re not the easiest thing to fit safely. Looking at a schematic I found online, the ignitor is actually 12vdc , they use a resistor to drop reduce the voltage so it might be possible to install a different fan and convert it to run entirely on 12vdc (I used a Mr Gasket carb fuel pump ran off of 12vdc) One thread I found about these heaters mention ditching the stock ignitor and using a car cigarette lighter element. I'm at the point now that I really don't feel that comfortable modifying something that burns raw fuel like these heaters! |
Lo-Fi Version | Time is now: 7th May 2024 - 10:00 AM |
