Rear suspension bushings, Winter project |
sixaddict |
Nov 23 2010, 11:22 AM
Senior Member Group: Members Posts: 800 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
I am planning to replace rear trailing arm bushings to stop the wretched squeaking and improve suspension travel. I was planning on smart racing poly graphite that may be lubricated, but noticed a competitor making a disparaging remark about that material.
Input on this would be appreciated. Which way is best based on your experience. Let the debate begin ! Thanks Terry |
J P Stein |
Nov 23 2010, 01:50 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
I did my rear with the needle bearing set up and have ever regretted it. I think Mark still sells them....not cheep, but effective and they have held up well.
Attached thumbnail(s) |
campbellcj |
Nov 25 2010, 10:09 AM
I can't Re Member Group: Members Posts: 4,544 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I now have the Elephant Polybronze in the back and they improved the smoothness of motion noticeably vs. the old Weltmeister polyurethane guys. I have needle bearings up front.
maf914 |
Dec 9 2010, 03:30 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
JP and Chris,
What sort of maintenance is required for the needle bearings? Did you install grease fittings? Any comments would be appreciated. Thanks. |
campbellcj |
Dec 9 2010, 03:54 PM
JP and Chris, What sort of maintenance is required for the needle bearings? Did you install grease fittings? Any comments would be appreciated. Thanks. Mine (front) do not have grease fittings. They should be disassembled, inspected, cleaned and lubed periodically. My new rear Elephant bushings do have grease fittings. The suspension tends to be torn down for maintenance and upgrades every couple years anyway so the bearing and bushing maintenance goes along with that. Since my car is track-focused and spends much of its life in the garage, it doesn't see crappy road/commuting conditions or nasty weather, which I imagine would decrease the service interval for these bits. |
Lo-Fi Version | Time is now: 13th May 2024 - 11:59 AM |
