WTB: Complete EFI setup for 2.0 engine |
SchantzMD |
Nov 24 2010, 03:07 PM
Newbie Group: Members Posts: 33 Joined: 15-June 06 From: Riverside ca Member No.: 6,233 |
Looking for a complete 2.0L EFI setup including:
MAP sensor (can be any type IV unit as long as it holds a vacuum, I can re-calibrate) ECU & wiring harness L & R Intakes All 4 Injectors Air intake box and associated mounted sensors Air filter assembly Old Hoses, fuel pumps, head temp sensors, fuel pressure regulators, fuel rails, and distributors, are not needed but can always be used. Also if this is a 73 setup an original head temp sensor and injector ballast resistor would be great to have too. An idea of price with shipping to CA will be appreciated. I'm Not 100% sure if I'll need this setup yet but if I do I'll email you back. Thanks in advance, Mike |
a914luvr |
Nov 25 2010, 07:18 PM
Member Group: Members Posts: 313 Joined: 6-February 03 From: Riverside, CA Member No.: 259 |
Hi Mike, I've got a '76 parts car here in Riverside with a 2L engine in it. Your welcome to the FI system if you decide you need it. I think it's all there except for the pressure sensor. You can have the FI for $150.
Lo-Fi Version | Time is now: 19th May 2024 - 07:45 AM |
