Looking for a complete 2.0L EFI setup including:
MAP sensor (can be any type IV unit as long as it holds a vacuum, I can re-calibrate)
ECU & wiring harness
L & R Intakes
All 4 Injectors
Air intake box and associated mounted sensors
Air filter assembly
Old Hoses, fuel pumps, head temp sensors, fuel pressure regulators, fuel rails, and distributors, are not needed but can always be used. Also if this is a 73 setup an original head temp sensor and injector ballast resistor would be great to have too.
An idea of price with shipping to CA will be appreciated.
I'm Not 100% sure if I'll need this setup yet but if I do I'll email you back.
Thanks in advance,
Mike
