Flasher problems |
Flasher problems |
dangrouche |
Nov 28 2010, 12:18 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
Emergency Flasher problem. Okay grounds and fuse terminals cleaned. PROBLEM: The rear end of the entire car does not light up when the emergency flasher switch is actuated. EVERYTHING ELSE WORKS. The left and front signals, stoplights, parking lights, headlight high and low beams all work as it supposed to. Dimmer of dash lights also works. When I put on the "European" light mode i.e., putting the turn signal lever left or right will illluminate the entire left side bulbs of the car or right. Pull the emergency switch and all the front end bulbs flash as they should but the tail end of the car is totally dark. Who suspects the flasher and who suspects the emergency switch? I substituted what I thought what is good flasher, but still the same symptom appears of inoperative rear lights. I have the flasher already on order, but want to check with the collective experience of the board.
Lo-Fi Version | Time is now: 19th May 2024 - 01:40 PM |
