Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
It was running, pulled due to worn out valve guides. all apart mostly cleaned, Heads are blasted, needs full rebuild, no valves, but has springs and shims. I think crank will polish out standard. Rods have perfect small end bushings and the case (4R) is timecerted. Alusil cylinders and pistons. CIS 3 bearing cams are cores (pitting), 4 bearing towers. All hardware, pump, intermediate shaft, etc.
Long block only. Has no lower valve covers or flywheel. $600. OBO plus shipping. $80. extra with lower turbo covers. (wanted to keep but willing to sell) $150. extra for '69 911 flywheel (correct for 914/901 trans), would need to be marked for 914. $800. OBO +shipping for all and I'll throw in a perfect looking 75 2.7 dizzy, and a good looking used PP and disc. Cheers Mark |
Lo-Fi Version | Time is now: 8th July 2025 - 10:41 AM |
