It was running, pulled due to worn out valve guides. all apart mostly cleaned, Heads are blasted, needs full rebuild, no valves, but has springs and shims. I think crank will polish out standard. Rods have perfect small end bushings and the case (4R) is timecerted. Alusil cylinders and pistons. CIS 3 bearing cams are cores (pitting), 4 bearing towers. All hardware, pump, intermediate shaft, etc.
Long block only. Has no lower valve covers or flywheel.
$600. OBO plus shipping.
$80. extra with lower turbo covers. (wanted to keep but willing to sell)
$150. extra for '69 911 flywheel (correct for 914/901 trans), would need to be marked for 914.
$800. OBO +shipping for all and I'll throw in a perfect looking 75 2.7 dizzy, and a good looking used PP and disc.
Cheers Mark
