full flow adaptor plate at oil filter mount |
realred914 |
Dec 2 2010, 10:57 AM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
hi; i want to make my new motor full flow, I will aalso be usign an aftermarket oil cooler with fan in addtion to the stock cooler, so i need to route some hoses and will require the larger high Pressure filter since this will be full flow.
since I will need to remote locate my filter I'd like to get a block off plate to replace the stock filter adaptor. ont hispalte i will have the in and out fittings to go to my hoses that will feed my relocated filter and extra cooler (and thermostat) at anyrate, who makes an adaptor plate with pipe threads for the in and out that fits were teh stock oil filter holder goes? anyone??? thanks |
bozo914 |
Dec 2 2010, 12:02 PM
Slacker Group: Members Posts: 284 Joined: 27-October 10 From: Richmond VA Member No.: 12,325 Region Association: MidAtlantic Region |
Bought one recently from CB Performance that threads on in place of the stock oil filter. Haven't installed it yet as am still getting parts together for the engine.
realred914 |
Dec 2 2010, 12:13 PM
Bought one recently from CB Performance that threads on in place of the stock oil filter. Haven't installed it yet as am still getting parts together for the engine. thanks, what I am looking to do is remove the stock filter holder (I plan on using a high pressure filter as this will be fullflow) adn decided for clearance issues to remote mount the filter. I also plan on an external cooler, so if I used the stock filter holder, plus a sandwhich adaptor for the cooler hoses and the larger High Pressure filter, I would not have space in the stock filter location. |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:12 PM |
