DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
BarberDave |
Barberdave ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest ![]() |
Dan: Don't know a thing about that company. But I have used a dash cap like that one for 5 yr. If you have a nice uncracked dash it's good Ins. and protection from the sun. The only time it.s not on the 914 is at a show or display. That price seems high to me . You could probbly get 1 here cheaper. My 2 cents./ Dave (IMG:style_emoticons/default/slap.gif) |
hot_shoe914 |
on ramp passer ![]() ![]() ![]() ![]() Group: Members Posts: 3,807 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None ![]() |
I bought one for a car but sold the car shortly after so I can't testify as to how they hold up. However, it did look good on the car and as for the price, I think I gotmine for 70 or 75 a couple years agoon Ebay.
Shoe |
Grelber |
Insert favorite Don Rickles joke here. ![]() ![]() ![]() Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region ![]() |
I have one on that I got from ebay for $75.00. It's only been on for a few months, but the fit is good, and unless you are right up on it, you can't tell it's not an original dash.
914itis |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States ![]() |
silver74insocal |
Senior Member ![]() ![]() ![]() Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California ![]() |
i wonder how good it actually fits as there is no distinction between late and early dashes (IMG:style_emoticons/default/popcorn[1].gif)
dangrouche |
dangrouche ![]() ![]() ![]() Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None ![]() |
Dan, I have a dash cap; not necessarily the one you got in your link, but found the same one you hyperlinked for $68.15
http://www.familycar.com/store/?Ntt=porsch...ap&oes=true Its pretty good, I have this one one on mine, it has a pebble finish, and is truly unnoticieable unless you grip the shell and pull it up. Ii doesn't need glue and I would not use double sided tape. I have removed it and it requires a little flexing to fit it. This dash pad is where I stick my Garmin plastic disc for the suction cup mount. I would say its the quickest way to stop having to stare at your dash cacks. I would buy it if I was not willing to change out the glass or recover the dash. I think Jeff Bowlsby is trying to sell an OEM one for more than $1000. |
DanT |
thanks for the link (IMG:style_emoticons/default/smile.gif)
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
The one's to protect the dash from cover king are really nice. Pelican has them.
carr914 |
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 125,838 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States ![]() ![]() |
If you have a nice uncracked dash it's good Ins. and protection from the sun. I actually think the opposite. If you have the cap on, the original dash will heat up and will not be able to breathe. I think it will crack more. The last car I took a cap off, was cracked beyond belief |
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
I've used two. Never needed glue. Didn't add cracks in the N Cal Bay Area. Hard to tell its hard plastic vs stock unless you have CW tendencies. Price is very reasonable vs the alternative.
BTW - be very careful with "perfect" dashes. I bought one over 12 years ago that had no cracks and was "perfect" until I dropped it, and the vinyl shattered. 30+ years of heat cycling will render all of them useless at some point.. |
StratPlayer |
StratPlayer ![]() ![]() ![]() ![]() Group: Members Posts: 3,335 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains ![]() ![]() ![]() |
If you have to glue them down then they suck.. Scroll to the bottom for the 914 cover, it's held in place by the A pillars
http://s244276042.onlinehome.us/redash%20pg.htm |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,752 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
I have a cap on my car that I got off eabay 3 or 4 years ago, and several folks have asked how my dash was uncracked. You can not tell it is a cap until you look close. The dead giveaway on my car is the ashtray opening, as there is no ashtray there now and you can see the cap lip.
Mine is not glued down, though it came with glue I did not use it and have had zero problems with it. Zach |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
monkeyboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None ![]() |
How did you do the repairs?
Beach914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 992 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California ![]() ![]() |
I bought one off of eBay from a guy in Phoenix and the ashtray opening was shifted almost 1/4" off location. I managed to get it to fit but had to glue it down to do it. I called him during the installation and he refused to admit that it was bad. I think it was a vacuum formed reject and he resell them cheaper.
I gave him average but not stellar feedback on eBay and he tried to slam me. eBay wiped his feedback of me off. I would do another, just not from him. |
Valy |
How did you do the repairs? Cross-posting the thread http://www.914club.com/bbs2/index.php?showtopic=210261 |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
I have one on my 73. Trick is to get the high spots out of your cracked dash first.
Attached thumbnail(s) ![]() |
reharvey |
Senior Member ![]() ![]() ![]() Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States ![]() |
My dash cap has been on for over 10 yrs. without a problem. It is glued down. Ray (IMG:style_emoticons/default/smile.gif)
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,735 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
If you have to glue them down then they suck.. Scroll to the bottom for the 914 cover, it's held in place by the A pillars http://s244276042.onlinehome.us/redash%20pg.htm Linky no bueno. (IMG:style_emoticons/default/WTF.gif) And you replaced that god awful brown dash face,too. ty. What did you do with the steering wheel in the first pic? |
Lo-Fi Version | Time is now: 3rd July 2025 - 07:07 AM |
