Lightweight Battery Poll |
campbellcj |
Dec 15 2010, 11:09 AM
I can't Re Member Group: Members Posts: 4,547 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I make it a habit to shut-off my kill switch when parking the car long-term. That way any passive drain isn't going to kill the battery, plus it is far less likely a short could cause a fire or I could shock myself while working on it.
Only downside is sometimes I crawl over the cage, attach the steering wheel, belt-in, and then realize I forgot to flip the switch on... |
windforfun |
Dec 15 2010, 11:42 AM
Senior Member Group: Members Posts: 1,830 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Although I have one in my 914, I never considered the Optima a lightweight battery. If anything I would call it a heavyweight battery, weighing in at 38 pounds. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) |
Root_Werks |
Dec 15 2010, 12:15 PM
Village Idiot Group: Members Posts: 8,332 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I make it a habit to shut-off my kill switch when parking the car long-term. That way any passive drain isn't going to kill the battery, plus it is far less likely a short could cause a fire or I could shock myself while working on it. Only downside is sometimes I crawl over the cage, attach the steering wheel, belt-in, and then realize I forgot to flip the switch on... I want to add a switch like that on my 914. My Squareback has one just behind the passanger seat. I can just reach back and flip it. |
JoeSharp |
Dec 15 2010, 03:43 PM
In Irvine, Ca. May 15-18 Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States |
The Odyssey 680 is not quite enough to start Carerror. By the time she is cranking there is only 9 volts at the CDI box. Going to put a larger battery in that corner of the car.
naro914 |
Dec 15 2010, 03:47 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
I have the Odyssey 925 with the Rennline mount up front. starts up a 3.2 six just fine.
J P Stein |
Dec 15 2010, 05:59 PM
The Odyssey 680 is not quite enough to start Carerror. By the time she is cranking there is only 9 volts at the CDI box. Going to put a larger battery in that corner of the car. You really should look at that OEM starter, Joe. (IMG:style_emoticons/default/biggrin.gif) |
carr914 |
Dec 15 2010, 07:13 PM
Racer from Birth Group: Members Posts: 118,949 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Here's another option I found this morning - Super Lightweight - under 12 lbs http://www.lithionicsbattery.com/racing.html The Manufacturer of these came by to see me today, the battery was quite impressive - I could pick it up by the Posts with 2 fingers. He was bragging a little too much and this Sucker is expensive ( over $1200 Retail), but Man, it floated on air |
campbellcj |
Dec 15 2010, 11:05 PM
The Odyssey 680 is not quite enough to start Carerror. By the time she is cranking there is only 9 volts at the CDI box. Going to put a larger battery in that corner of the car. Something sounds wrong with that. Guys are using these to crank high compression -6 race engines and probably V8's as well. Are you getting full current to the starter? |
Eddie914 |
Dec 16 2010, 11:37 AM
Unregistered |
How about something like this:
http://www.sears.com/shc/s/p_10153_12605_02827185000P?mv=rr For only $49.99 ... it might be worth a try ... less than 1/2 the price of an Odyssey. Eddie |
carr914 |
Dec 16 2010, 03:57 PM
Not enough CCAs
gothspeed |
Dec 13 2013, 09:16 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
When are these batteries gonna be available? (IMG:style_emoticons/default/biggrin.gif) http://press.porsche.com/news/release.php?id=510 Attached image(s) |
brant |
Dec 13 2013, 09:30 PM
914 Wizard Group: Members Posts: 11,635 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
They are available now.
Bring money! |
gothspeed |
Dec 13 2013, 09:49 PM
Are there any 'aftermarket' versions of them? Unfortunately I can only afford about 25% of the $2000-ish MSRP for a hi-tech battery ...... I guess an odyssey is still the front runner for me ..... (IMG:style_emoticons/default/popcorn[1].gif)
Woody |
Dec 13 2013, 10:05 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
When are these batteries gonna be available? (IMG:style_emoticons/default/biggrin.gif) http://press.porsche.com/news/release.php?id=510 We have one in stock. |
gothspeed |
Dec 14 2013, 12:17 AM
When are these batteries gonna be available? (IMG:style_emoticons/default/biggrin.gif) http://press.porsche.com/news/release.php?id=510 We have one in stock. What is the current price (IMG:style_emoticons/default/smile.gif)? I was hoping the price might come down a bit, since apparently they have been out a while. |
carr914 |
Dec 14 2013, 04:32 AM
^ I thought they were about $4k ^
Braille has a 6lb Battery out Now |
1stworks |
Dec 14 2013, 08:11 AM
Member Group: Members Posts: 491 Joined: 31-March 13 From: colorado Member No.: 15,718 Region Association: None |
gothspeed |
Dec 14 2013, 09:36 AM
Those braille batteries look pretty good (IMG:style_emoticons/default/smile.gif) . looks like a direct competitor to odyssey.
carr914 |
Dec 14 2013, 11:41 AM
Those braille batteries look pretty good (IMG:style_emoticons/default/smile.gif) . looks like a direct competitor to odyssey. Braille are Lithium Ion & Odyssey are still a Lead Acid (Sealed, Pure Lead & Compact like the Optima) |
jimkelly |
Dec 14 2013, 12:05 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
Lo-Fi Version | Time is now: 5th June 2024 - 05:28 AM |
