Installed 911 Aluminum Auxiliary Support (Front Cross Member), Now Protective Plate Doesn't Fit. Solutions? |
mwyatt |
Dec 14 2010, 01:33 AM
Member Group: Members Posts: 84 Joined: 5-April 03 From: San Diego, CA Member No.: 516 Region Association: Southern California |
Hi guys. I installed an Aluminum Auxiliary Support in my 914 this weekend. It bolts right up, but it comes down lower than the steel piece and now the stock 914 underfloor protective plate doesn't fit. There are also no holes in the support for the plate to screw into in the front, but the two bolts in the rear are fine (see attached pic from the front).
I know I can't be the only one that has done this. What have others done to make the protective plate work? By the way, for those that have been thinking about doing this, I probably wouldn't recommend it. I'd guess it's only 3 or 4 pounds lighter than the steel piece, and some have suggested that it can flex. But I'm committed at this point to trying to make it work. - Mike |
r_towle |
Dec 14 2010, 10:08 AM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
drill two small screw holes in the flange of the support bar and fasten it that way.
Its made for a 911, so the stock 914 holes would never have been cast. Rich |
mwyatt |
Dec 14 2010, 11:59 AM
Thanks Rich, makes sense. And I suppose I could also make a gasket and attach it to the two original front holes in the protective plate to keep the seal it off.
Cap'n Krusty |
Dec 14 2010, 12:02 PM
Have you looked into fitting the 911 plate?
The Cap'n |
mwyatt |
Dec 14 2010, 12:16 PM
pete000 |
Dec 14 2010, 01:09 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
4 lbs is 4 lbs !
I have to diet for a month and go to the gym twice a day to loose 4 lbs ! Was the job easy, I want to do this on my 914 soon. |
Cap'n Krusty |
Dec 14 2010, 01:35 PM
mwyatt |
Dec 14 2010, 03:58 PM
4 lbs is 4 lbs ! I have to diet for a month and go to the gym twice a day to loose 4 lbs ! Was the job easy, I want to do this on my 914 soon. Pete, the job is fairly easy. Make sure you measure your front ride height on each side of the car before you take everything apart, because you'll have to reset it. Cap'n, I'll see if I can pick up a Carrera protective plate and let everyone know if it works. |
mwyatt |
Jan 10 2011, 11:43 PM
I picked up a protective plate from a '77 911 and it fit really well. I got it from Parts Heaven. Didn't come with gaskets, so I made some and it works fine. For those that want to do this, for the entire project you need three items-
Aluminum Crossmember Tabs (2 of them, they bolt to the cross member and on 911s mount the underbody swaybar) 911 Protective Plate |
jt914-6 |
Jan 11 2011, 05:22 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
URY914 |
Jan 11 2011, 07:50 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,693 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
This really isn't worth the effort. Removing 4 pounds at the lowest part of you car actually raises your center of gravity of the car. I have the lightest car ever and I won't be doing this to my car.
Cap'n Krusty |
Jan 11 2011, 09:47 AM
I picked up a protective plate from a '77 911 and it fit really well. I got it from Parts Heaven. Didn't come with gaskets, so I made some and it works fine. For those that want to do this, for the entire project you need three items- Aluminum Crossmember Tabs (2 of them, they bolt to the cross member and on 911s mount the underbody swaybar) 911 Protective Plate It didn't come with gaskets because it doesn't use gaskets. The Cap'n |
Britain Smith |
Jan 11 2011, 09:20 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
You know that the aluminum crossbar flexes...ask SirAndy.
-Britain |
Chris Hamilton |
Jan 11 2011, 10:35 PM
Senior Member Group: Members Posts: 611 Joined: 7-March 06 From: Berkeley, CA Member No.: 5,687 |
This really isn't worth the effort. Removing 4 pounds at the lowest part of you car actually raises your center of gravity of the car. I have the lightest car ever and I won't be doing this to my car. So are you going to add a 4lbs weight to your steel crossbar and make your center of gravity even better? (IMG:style_emoticons/default/happy11.gif) |
Richard Casto |
Jan 12 2011, 10:03 AM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
This really isn't worth the effort. Removing 4 pounds at the lowest part of you car actually raises your center of gravity of the car. I have the lightest car ever and I won't be doing this to my car. So are you going to add a 4lbs weight to your steel crossbar and make your center of gravity even better? (IMG:style_emoticons/default/happy11.gif) Zing! Good one! (IMG:style_emoticons/default/smile.gif) Clearly you want to lower both weight and CG, but if you had to pick one over the other, I would say the priority is to first lower weight and then second lower CG. And when done, if you end up removing more weight below the CG than above (which would move the new CG up), so be it. When you have to deal with a minimum weight requirement, and you are able to build the car to below minimum, then you can work to get the CG as low as possible by putting ballast as low as possible. Now the real world benefits of the aluminum cross bar is another story. But, I have one and plan to put it on my car. Richard |
Lo-Fi Version | Time is now: 19th May 2024 - 11:22 AM |
