Any body doing this ? 914 w/Hayabusa motor . ?, pro's con's , support or poke holes. Wtb : your 2 cents |
thelogo |
Dec 16 2010, 02:10 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
http://cgi.ebay.com/ebaymotors/09-SUZUKI-H...ht_10790wt_1167
Just wondering would this engine be viable for a conversion . It makes good power . small , water cooled . f. i . wet sump . Is it as simple as toss the type 4 . clutch adapter kit and wiring or is it much more complex . The radiator is Tiny . smaller then most oil coolers ? so It would not need front mounted huge heat exchanger ? for some reason it runs right next to the header pipe ??? Please give me your thought's . pro's con's cost s ability to go back to type 4 motor if desired ? hey o . http://www.youtube.com/watch?v=gbBfDOPeZ2g (IMG:style_emoticons/default/flag.gif) Much respect and thank you to BOB FELLER > for being a positive role model (IMG:style_emoticons/default/flag.gif) Attached thumbnail(s) |
RJMII |
Dec 16 2010, 02:41 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
I've been eyeballing these units for sometime now. My plan is to build a sandrail (the Baracuda by the EDGE) with a 'busa power plant.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.sandbullet.com-8112-1292532070.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.sandbullet.com-8112-1292532072.2.jpg) Rear dif with reverse. (IMG:style_emoticons/default/smile.gif) QUOTE new rear drive system can be done with or with out reverse but also includes the following features: Chain drive with rear sprocket as large as 72 tooth Inboard or out board brakes Limited slip differential or solid axle 930 CV output Adjust chain tension on chain roller needed (http://www.sandbullet.com) |
Lo-Fi Version | Time is now: 15th May 2024 - 01:49 PM |
