Any body doing this ? 914 w/Hayabusa motor . ?, pro's con's , support or poke holes. Wtb : your 2 cents |
thelogo |
Dec 16 2010, 02:10 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
http://cgi.ebay.com/ebaymotors/09-SUZUKI-H...ht_10790wt_1167
Just wondering would this engine be viable for a conversion . It makes good power . small , water cooled . f. i . wet sump . Is it as simple as toss the type 4 . clutch adapter kit and wiring or is it much more complex . The radiator is Tiny . smaller then most oil coolers ? so It would not need front mounted huge heat exchanger ? for some reason it runs right next to the header pipe ??? Please give me your thought's . pro's con's cost s ability to go back to type 4 motor if desired ? hey o . http://www.youtube.com/watch?v=gbBfDOPeZ2g (IMG:style_emoticons/default/flag.gif) Much respect and thank you to BOB FELLER > for being a positive role model (IMG:style_emoticons/default/flag.gif) Attached thumbnail(s) |
Porcharu |
Dec 16 2010, 04:26 PM
Senior Member Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
I want the V8 version like the one Radical sells for $$$$. Someone in the midwest used to make the crankcase assembly's that you bolted 2 sets of cylinders and heads onto.
2.6 liters of screaming little V8 would be a blast in a 914. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:03 PM |
