Any body doing this ? 914 w/Hayabusa motor . ?, pro's con's , support or poke holes. Wtb : your 2 cents |
thelogo |
Dec 16 2010, 02:10 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
http://cgi.ebay.com/ebaymotors/09-SUZUKI-H...ht_10790wt_1167
Just wondering would this engine be viable for a conversion . It makes good power . small , water cooled . f. i . wet sump . Is it as simple as toss the type 4 . clutch adapter kit and wiring or is it much more complex . The radiator is Tiny . smaller then most oil coolers ? so It would not need front mounted huge heat exchanger ? for some reason it runs right next to the header pipe ??? Please give me your thought's . pro's con's cost s ability to go back to type 4 motor if desired ? hey o . http://www.youtube.com/watch?v=gbBfDOPeZ2g (IMG:style_emoticons/default/flag.gif) Much respect and thank you to BOB FELLER > for being a positive role model (IMG:style_emoticons/default/flag.gif) Attached thumbnail(s) |
gothspeed |
Dec 16 2010, 08:41 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
An S2000 motor would be even more awesome (IMG:style_emoticons/default/smile.gif)!! 240hp bone stock!! Kennedy makes the adapter plate. The only thing to make sure of is the rotation of the crank.
campbellcj |
Dec 17 2010, 11:23 PM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
An S2000 motor would be even more awesome (IMG:style_emoticons/default/smile.gif)!! 240hp bone stock!! Kennedy makes the adapter plate. The only thing to make sure of is the rotation of the crank. Don't they have a peaky minimal low-RPM torque powerband as well? As conversions go, a compact turbo like a Subie sounds good to me. Although I am not an engine swap kinda guy at this point. (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 01:01 PM |
