Any body doing this ? 914 w/Hayabusa motor . ?, pro's con's , support or poke holes. Wtb : your 2 cents |
thelogo |
Dec 16 2010, 02:10 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
http://cgi.ebay.com/ebaymotors/09-SUZUKI-H...ht_10790wt_1167
Just wondering would this engine be viable for a conversion . It makes good power . small , water cooled . f. i . wet sump . Is it as simple as toss the type 4 . clutch adapter kit and wiring or is it much more complex . The radiator is Tiny . smaller then most oil coolers ? so It would not need front mounted huge heat exchanger ? for some reason it runs right next to the header pipe ??? Please give me your thought's . pro's con's cost s ability to go back to type 4 motor if desired ? hey o . http://www.youtube.com/watch?v=gbBfDOPeZ2g (IMG:style_emoticons/default/flag.gif) Much respect and thank you to BOB FELLER > for being a positive role model (IMG:style_emoticons/default/flag.gif) Attached thumbnail(s) |
Justinp71 |
May 6 2014, 08:23 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I really like the audi 1.8T (Like Mike Bellis's) or the WRX turbo motor in these cars. I bet the larger 4 cylinder turbo makes a great combo...
Mike Bellis |
May 18 2014, 01:06 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I really like the audi 1.8T (Like Mike Bellis's) or the WRX turbo motor in these cars. I bet the larger 4 cylinder turbo makes a great combo... What makes my conversion work is the tune. Using a factory ECU tuned for a big turbo and methanol is awesome. It runs like a mild mannered Audi around town. If you put your foot into it, the motor comes alive and is a blast to drive. Once I get the drivetrain relocated in the chassis, the car will be mechanically perfect. Nothing wrong with aftermarket ECU's. But I don't think they have the driveability or computing power of a factory ECU. The aftermarket can be tuned to give similar power results but still won't drive as well. I have no flt spots, no jerkyness, perfect idle, near perfect AF mixture, easy cold weather starting, and on and on. I think the Bosch Motronic 7.5 I'm running could be adapted to any engine if you have a good tuner. |
Lo-Fi Version | Time is now: 16th May 2024 - 02:41 AM |
