"74" heater blower motor, where is it? |
mrbubblehead |
Dec 18 2010, 11:10 AM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i have these tubes that come up thru the tin. they look like tubes for the heater. but there in no heater/blower motor in the engine compartment. im thinking the po took it out. i already dropped my bottle of locktite down on of the tubes (IMG:style_emoticons/default/headbang.gif) it was a PIA to get it out. so did the 74s have a blower motor back there?
tango-52 |
Dec 18 2010, 11:20 AM
Member Group: Members Posts: 149 Joined: 18-October 07 From: San Diego County Member No.: 8,243 Region Association: Southern California |
Mine does. I believe it mounts on that blue protrusion you see on the left side of your picture.
jim912928 |
Dec 18 2010, 11:22 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Yep...it attaches to the curved bracket you see on the left attached to the engine shelf.
stugray |
Dec 18 2010, 11:24 AM
The blower motor was bolted onto the fan shroud with an angle bracket.
You are clearly missing it. 5 Hot Air Blower 70-72 Part # 473 261 193 Stu |
Lennies914 |
Dec 18 2010, 11:32 AM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
JeffBowlsby |
Dec 18 2010, 12:08 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The blower motor was bolted onto the fan shroud with an angle bracket. You are clearly missing it. 5 Hot Air Blower 70-72 Part # 473 261 193 Stu Misinformation. Its correct for the 1970-72 cars, but the later cars 73-forward were mounted on the radiused bracket to the left of the engine. (IMG:style_emoticons/default/thumb3d.gif) |
mrbubblehead |
Dec 18 2010, 12:24 PM
great thanks guys. now i just need to find one. ARGHHH. i assume the power comes off of the relay to power it up. correct?
does anyone have a working 12volt heater blower motor their not using that they want to sell? |
dr914@autoatlanta.com |
Dec 18 2010, 12:35 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
great thanks guys. now i just need to find one. ARGHHH. i assume the power comes off of the relay to power it up. correct? does anyone have a working 12volt heater blower motor their not using that they want to sell? 74 had the motor mounted in the cradle on the left engine shelf clamped and resting in a rubber pad with only one hose attached to the left drivers j pipe coming up through the engine sheet metal cylinder shroud. The right passenger side was capped off. By the middle of 75 Porsche added an additional hose over to the right side and a branch piece to the motor to supplement the blow. In the 80s they discontinued this branch so we had them made and sell them as our heater blower update kit. Actually even without the blower motor, the impeller fan will blow heat forward, just not as violently. The six cylinders had a larger fan and provided very very good heat flow without the need for any kind of additional electrical blower. Heater blower motors for all 914s even the 73-76 style have been discontinued by the factory but there are many available on e bay cheaply or if you need one instantly we have plenty of good used ones in stock removed from very low mile 914s years ago (they never went bad back then!!!) |
Drums66 |
Dec 18 2010, 12:44 PM
.....Mr. bubblehead..I see you're in La Mesa?? I have a storage facility over in
chula vista (IMG:style_emoticons/default/idea.gif) with what you need there..PM me your # so we can discuss (IMG:style_emoticons/default/bye1.gif) |
mrbubblehead |
Dec 18 2010, 12:54 PM
.....Mr. bubblehead..I see you're in La Mesa?? I have a storage facility over in chula vista (IMG:style_emoticons/default/idea.gif) with what you need there..PM me your # so we can discuss (IMG:style_emoticons/default/bye1.gif) CALImesa. pm on the way. |
Dec 18 2010, 02:03 PM
Resident German Group: Admin Posts: 41,641 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
great thanks guys. now i just need to find one. ARGHHH. i assume the power comes off of the relay to power it up. correct? That would be correct, the connector comes out of the main harness but is powered by the relay board. Except, it looks like your wiring harness is all hacked up back there where it runs along the firewall. I'd be very surprised if you can find the stock wiring for the heater blower ... (IMG:style_emoticons/default/sad.gif) |
silver74insocal |
Dec 18 2010, 02:29 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
howdy neighbor and (IMG:style_emoticons/default/welcome.png)
goto the classified forums and start yourself a WTB thread named "74 heater blower motor" several will pop up rather quickly. also you and i are fortunate to live very close to some of the best parts guys for these little cars 2 of which live in Riverside, so you really shouldnt need to pay for shipping if you can come down the 10 and pick one up finally, feel free to pm me if you need any help with any of this stuff . welcome to the madness, Dave (IMG:style_emoticons/default/beerchug.gif) |
championgt1 |
Dec 18 2010, 03:51 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
GeorgeRud |
Dec 18 2010, 03:58 PM
Didn't someone sell an adapter that split the air hose coming from the blower motor into two separate hoses to run to the passenger side exchanger as well? I seem to remember bying one years ago when my 73 had the original four cylinder engine installed.
stugray |
Dec 18 2010, 04:37 PM
"Misinformation."
Yeah, sorry. I have only owned two 71s so I have never seen the blower anywhere else. I have one that I dont need. Stu |
timofly |
Dec 18 2010, 04:39 PM
Member Group: Members Posts: 164 Joined: 21-February 09 From: VA Member No.: 10,082 Region Association: MidAtlantic Region |
i have these tubes that come up thru the tin. they look like tubes for the heater. but there in no heater/blower motor in the engine compartment. im thinking the po took it out. i already dropped my bottle of locktite down on of the tubes (IMG:style_emoticons/default/headbang.gif) it was a PIA to get it out. so did the 74s have a blower motor back there? Bubbles, there are two different blowers. The 74 had one with two outlets that mounted on the shroud as someone else said. The earlier motor has just one outlet, but there is an adapter to split the output from the single-output version. You might want to do that because the bracket to attach the two-outlet motor is NLA, according to AA. The two outlet kind might be hard to find, but the single ones are common. I have the single blower on my 74, attached it to the mount with a piece of rubber and a big hose clamp. I made up a splitter from a PVC "Y" and some flexible exhaust ducting, plus some hi-temp duct tape (only because it's in the engine compartment: the blower only blows cold air into the tubes.) It works fine. I am on backorder for the long right tube and will replace the exhaust duct when it arrives. Of course, as soon as I got it done, we had our first dusting of snow and the geniuses in town decided to throw salt around on the roads, so 914 is confined to the barn and the driveway until we get a nice heavy rain... Do I need to warn you to be sure your heat exchangers are solid? If there are any leaks theymay allow CO into the cabin. You get a nice, but very long, nap. Why do YOU need heat? I thought S CA was always warm. |
jaxdream |
Dec 19 2010, 08:38 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Not to hijack , but what type of ignition are you running ??? It appears that you're also running a single carb setup also.
Jack / Jaxdream |
mrbubblehead |
Dec 19 2010, 10:50 AM
sirandy, good eye on the harness. i have found the stock heater wire so im golden.
silver74, thanks for the info thats good to know. im in riverside often. drum66 i suppose to hook me up with the whole set up. if not, i will surely call on you. (IMG:style_emoticons/default/beerchug.gif) championgt1 thank you for posting. that is exactly the picture i need. timofly i need heat because im a big sissy. jaxdream the ignition is from my old class 5 car. it is a compufire dis-ix |
hot_shoe914 |
Dec 19 2010, 04:54 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
I think you are going to find that you will have plenty of heat (especially in Cali) without the blower motor. I drove from Memphis to Kansas in February and never turned the blower on and I almost roasted. Short sleeves all the way, even at night.
mrbubblehead |
Dec 19 2010, 06:49 PM
I think you are going to find that you will have plenty of heat (especially in Cali) without the blower motor. I drove from Memphis to Kansas in February and never turned the blower on and I almost roasted. Short sleeves all the way, even at night. really? i havnt really driven this car yet so i dont know what to expect. i just got the whole setup and it was fairly inexpensive. so i will have it just in case. who knows i might want to drive up to alaska or something. |
Lo-Fi Version | Time is now: 17th May 2024 - 08:51 PM |
