QUOTE(mrbubblehead @ Dec 18 2010, 12:10 PM)
i have these tubes that come up thru the tin. they look like tubes for the heater. but there in no heater/blower motor in the engine compartment. im thinking the po took it out. i already dropped my bottle of locktite down on of the tubes
it was a PIA to get it out. so did the 74s have a blower motor back there?
Click to view attachmentBubbles, there are two different blowers.
The 74 had one with two outlets that mounted on the shroud as someone else said. The earlier motor has just one outlet, but there is an adapter to split the output from the single-output version. You might want to do that because the bracket to attach the two-outlet motor is NLA, according to AA. The two outlet kind might be hard to find, but the single ones are common.
I have the single blower on my 74, attached it to the mount with a piece of rubber and a big hose clamp. I made up a splitter from a PVC "Y" and some flexible exhaust ducting, plus some hi-temp duct tape (only because it's in the engine compartment: the blower only blows cold air into the tubes.) It works fine. I am on backorder for the long right tube and will replace the exhaust duct when it arrives. Of course, as soon as I got it done, we had our first dusting of snow and the geniuses in town decided to throw salt around on the roads, so 914 is confined to the barn and the driveway until we get a nice heavy rain...
Do I need to warn you to be sure your heat exchangers are solid? If there are any leaks theymay allow CO into the cabin. You get a nice, but very long, nap.
Why do YOU need heat? I thought S CA was always warm.
