2 Pages V < 1 2
> Ok I got my Trans out..., Now what?
Dr Evil
post Dec 26 2010, 02:59 PM
Post #21
Send me your transmission!
Can I get an amen?
RJMII does these now (IMG:style_emoticons/default/smile.gif)
r_towle
post Dec 26 2010, 05:29 PM
Post #22
Custom Member
I second getting new washers...
Also, get a can of undercoating...clean that bottom up and stop trying to spend money.... (IMG:style_emoticons/default/smile.gif)
Rich
rwilner
post Dec 26 2010, 06:46 PM
Post #23
No Ghosts in the Machine
QUOTE(r_towle @ Dec 26 2010, 06:29 PM) *
Says the guy building a 356 in his barn (IMG:style_emoticons/default/smile.gif)
I have learned in my short tenure with my 914 that this is not a good car to own if you don't enjoy buying parts and replacing them, much like any 40 year old car, i would imagine.
Better than a drug habit!
(but no less addictive)
rwilner
post Dec 26 2010, 10:19 PM
Post #24
QUOTE(Dr Evil @ Dec 26 2010, 03:59 PM) *
Can I get an amen?
ok, i will bite. drilled for safety wire??
my guess is someone drilled holes in the screw caps, after you install the screws, you feed wire through the caps, which prevents them from loosening up?
pelican has the triple square ones for 0.75 ea, where can I get these drilled ones?
Cap'n Krusty
post Dec 26 2010, 10:36 PM
Post #25
Cap'n Krusty
Replace that inop thermostat ............................
The Cap'n
bigkensteele
post Dec 26 2010, 10:51 PM
Post #26
Major Member
QUOTE(Richard Casto @ Dec 24 2010, 06:23 PM) *
QUOTE(rwilner @ Dec 24 2010, 03:12 PM) *
I got my trans out of the car, packed, and shipped down to Richard Casto at Blue Sky for a rebuild.
If only Greyhound would finish shipping it, I could start work on it! I suspect the delay is a victim of holiday travel demand.
Richard
My previous employer (and the worst company in the Western Hemisphere to work for) is the parent company of Greyhound. I am familiar with their shipping systems. Let us all pray that said transmission arrives one day.
rwilner
post Dec 27 2010, 08:46 AM
Post #27
QUOTE(Cap'n Krusty @ Dec 26 2010, 11:36 PM) *
The Cap'n
any idea where I can get my hands on one?
Update: george has them in stock.
ChrisFoley
post Dec 27 2010, 12:13 PM
Post #28
I am Tangerine Racing
QUOTE(Dr Evil @ Dec 24 2010, 03:50 PM) *
... you do not need the paper CV gaskets. They shrink and expand allowing for the bolts to come loose and fall out. Many have abandoned the gaskets, including myself, and now just bolt the CV on, clean the outer mating surface with solvent, and seal with RTV. Works good (IMG:style_emoticons/default/smile.gif)
I strongly disagree!
The stock paper gaskets are the best way to prevent slinging grease onto the trunk floor, starter, etc.
Expansion/contraction of the gaskets has absolutely nothing to do with the bolts loosening up.
The CVs are designed with a space for the gasket, such that the CV is still bolted metal to metal. Correct torque and new Schnorr washers is the key.
I've never used the bolts drilled for safety wire and probably never will.
In my on-track experience, RTV will not hold up to the centrifugal force of a spinning axle, and will let go prematurely - allowing the grease out.
No gasket at all is a sure way to dry out your CVs and to mess up the underside of your car. (IMG:style_emoticons/default/screwy.gif)
Dr Evil
post Dec 27 2010, 12:15 PM
Post #29
In my experience, high temp silicone has always worked. Never let me down.
ChrisFoley
post Dec 27 2010, 12:21 PM
Post #30
How long do you have to wait to drive the car?
With gaskets its "torque and go". (IMG:style_emoticons/default/smile.gif)
Dr Evil
post Dec 27 2010, 12:30 PM
Post #31
(IMG:style_emoticons/default/tongue.gif)
Richard Casto
post Dec 27 2010, 06:40 PM
Post #32
Blue Sky Motorsports, LLC
QUOTE(bigkensteele @ Dec 26 2010, 11:51 PM) *
Richard
Transmission has arrived. I think the delay was due to to the holiday travel traffic. So far I have been happy with Greyhound, but in general I think all shipping companies are evil as I really don't think they care about service.
QUOTE(rwilner @ Dec 26 2010, 11:19 PM) *
Can I get an amen?
Correct on the safety wire. Regarding sourcing, I don't think any of the typical suppliers offer them as to the best of my knowledge these are standard bolts that are drilled by hand (using a jig or otherwise). As Dr. Evil says RJMII took over doing that once Dr. Evil stopped. I don't know if RJMII is still doing those or not. PM him to find out if you are interested in going that route. I plan to start offering them myself (along with regular style), but am not ready to do so just yet. Clearly, the stock setup works and has for decades, but the safety wire setup adds additional protection.
Also as we talked about earlier, you should use new Schnorr washer on reassembly and new cap head bolts if yours are not in good condition.
I will let Dr. Evil and Racer Chris fight it out over the CV gaskets! Personally I have never had issues with using the paper gaskets. But! I do agree with the point that both have made in their own way that if you are not metal to metal and not using good hardware when you torque the bolts, it's not going to work.
Richard
2 Pages V < 1 2
- Lo-Fi Version Time is now: 3rd July 2025 - 06:15 PM
