SOLD***FS: motor, size: 1911, Bay Area |
BuddyV |
Dec 24 2010, 02:22 PM
Robert Group: Members Posts: 555 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
*** SOLD****
I recently bought a 2.0 from a member of this site, so I no longer need the motor I was planning to drop BACK into my car. History: I bought this motor in parts (new or restored) from a guy with a garage at Infineon Raceway. He had gathered all of the parts over a long while to build a 1911 for his daughter's 914. Well, he never got to it, so I bought the entire, well-sorted lot that came in around (10) boxes. The case is a 1.7 and he had brand new 96mm pistons and a "mild" cam that I never bothered to identify (should have, I guess). The seller is a master mechanic and was going to use the cam, so I trusted his opinion. The heads were stock and clean, but I still had my machinist clean them up. I am looking for the receipt from him to say exactly what he did to them. I ran the motor for a short while - it ran awesome. Not tremendous power, but smooth and plenty of power. I ran it with carbs that were a bit large for them, 44 webers. Well, one day while filling the tires with air, the motor would not re-start at the gas station. I eventually called my mechanic. He discovered that the brass gear on the crank that turns the distributor had "shifted". He had not seen that happen in 20+ years. So he pulled the motor and stood behind his work by taking the motor apart and replacing all parts that could be a problem. The motor has been reassembled for over a year. I was just about to drop it back in when I found my current motor at a great price, installed. I am VERY short on time, so this new motor was a way to get back on the road ASAP. (and I made friends with Mike Kooz in the process!) So, the 1911 is available. No trans or heat exchangers/exhaust. I sold the carbs shortly after pulling the motor, so you would need carbs. All of the engine tin is pulled from the motor and is part of the sale. I am offering the motor for $900. I know that I paid about that for the head work. Hopefully someone on this site can appreciate a nicely-built 1911. Again, motor will need CARBS, EXHAUST, HEAT EXCHANGERS. All else is included. Cheers! Robert (707) 888-1857 ps - I am located near Santa Rosa, California. Local pick up preferred, but I do have the motor on a pallet, wrapped up. I could aid in shipping if you manage the details. |
Lo-Fi Version | Time is now: 25th May 2024 - 07:07 AM |
