Rear Sway Bar Mounting, Source for mounting tabs and reinforcement plate? |
Sailor |
Dec 25 2010, 12:24 AM
Member Group: Members Posts: 67 Joined: 17-January 10 From: Tumwater, WA Member No.: 11,247 Region Association: Pacific Northwest |
I am contemplating installing a rear sway bar and am trying to locate a source for the mounting tabs and reinforcing plate. PP lists them as NLA. Have an opportunity to pick bar from a local parts car but will pass if I can't source the mounting hardware.
914werke |
Dec 25 2010, 01:49 AM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Try Engman he has an ad/link in me member vendors section
(IMG:style_emoticons/default/smile.gif) |
sww914 |
Dec 25 2010, 02:43 AM
I just installed a set, got them from GPR. It's actually Johnathan's car, so he got them from himself. (IMG:style_emoticons/default/smile.gif)
badm |
Dec 25 2010, 08:22 AM
Member Group: Members Posts: 213 Joined: 10-May 09 From: Cape Cod Taxachusetts Member No.: 10,350 Region Association: North East States |
Engman Kit weld and bolt. http://engmanparts.com/chassis.php
Some photos of the work. Weld bracket tab to crossmember. Coat with primer/paint Paint suport plates for inside trunk. Coat with undercoating. Install new shock bolt for sway bar. Install sway bar. your done. |
Sailor |
Dec 25 2010, 09:58 AM
Engman Kit weld and bolt. http://engmanparts.com/chassis.php Thanks, the photos are a great help in seeing how the install is done. Is the backing plate welded in the trunk or just bolted? I assume the later since it was painted prior to install. |
badm |
Dec 25 2010, 10:30 AM
QUOTE Thanks, the photos are a great help in seeing how the install is done. Is the backing plate welded in the trunk or just bolted? I assume the later since it was painted prior to install. I bolted the plates as well as 2 part epox, But I wold weld if I was doing this befor I painted the car |
Sailor |
Dec 27 2010, 10:01 AM
QUOTE I bolted the plates as well as 2 part epox, But I wold weld if I was doing this befor I painted the car Thanks for the info, you wouldn't have a picture of the inside of the trunk would you? |
badm |
Dec 27 2010, 10:25 AM
QUOTE I bolted the plates as well as 2 part epox, But I wold weld if I was doing this befor I painted the car Thanks for the info, you wouldn't have a picture of the inside of the trunk would you? I dont but I will get out to the garage at some point today and get a photo, are there any others you want?Badm. |
Eric_Shea |
Dec 27 2010, 10:57 AM
Here's some showing the inside of the trunk mount:
Hard to see any detail from this but, we soda blasted the car, welded in the reinforcement and this shot is the Wurth undercoating going on before paint: (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-1110-1293469032.1.jpg) |
Sailor |
Dec 27 2010, 01:00 PM
QUOTE I dont but I will get out to the garage at some point today and get a photo, are there any others you want?Badm. That should do it , thanks. |
badm |
Dec 27 2010, 04:34 PM
QUOTE I dont but I will get out to the garage at some point today and get a photo, are there any others you want?Badm. That should do it , thanks. The plates had a flush mount grade 8 allen head bolt welded in befor paint, epoxy between plate and floor, grade 8 nylock nut. Badm. |
Dec 27 2010, 05:11 PM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I welded in the support and bracket ...
(IMG:http://www.914world.com/bbs2/uploads/post-2-1137991455.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-2-1137991385.jpg) (IMG:http://www.914world.com/bbs2/uploads/post-2-1137991575.jpg) |
Sailor |
Dec 27 2010, 11:40 PM
Thanks everyone for the photos, they are very helpful. Just picked up a set of stock sway bars today. Hope to have them in by spring. (IMG:style_emoticons/default/beerchug.gif)
Eric_Shea |
Dec 28 2010, 11:16 AM
Congratulations. You're going to love the difference.
I think they (the front at least) should have come standard on a 914. |
913B |
Jan 20 2013, 10:50 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Anyone have new source for these brackets to install the rear sway bars ?
Mark Henry |
Jan 20 2013, 11:03 PM
Mike Bellis |
Jan 20 2013, 11:06 PM
Anyone have new source for these brackets to install the rear sway bars ? I don't know where to buy but... It looks super easy to fabricate... (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) |
mr914 |
Jan 21 2013, 03:59 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
With the passing of Engman
I will be fabricating a set for myself, the rear mount tabs are 1" x 1/8" plate The only challenge is making the two 90 degree bends about 1/2" from each other. The rest is skill level 1.5. Drill and hacksaw to fabricate Installation requires more skill and equipment (IMG:style_emoticons/default/welder.gif) |
scott_in_nh |
Jan 21 2013, 06:21 PM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
They are not listed on his website, but you can get that from Racer Chris at CFR - Tangerine Racing.
I know because I got mine from him recently... http://www.tangerineracing.com/contact_us.htm |
ChrisFoley |
Jan 22 2013, 08:09 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
They are not listed on his website, but you can get that from Racer Chris at CFR - Tangerine Racing. I know because I got mine from him recently... http://www.tangerineracing.com/contact_us.htm They will be in the new website that's nearly ready to go live. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 11:55 PM |
