Teeners race cars, without sails |
Randal |
Dec 28 2010, 10:57 AM
Got pictures? |
J P Stein |
Dec 28 2010, 01:22 PM
I'm sure some one could photochop a pic if you gave em' a good profile shot.
The 914 look is gone without the sail. Someone did mine a few years back. That is slipping mighty close to 17.2.S or 18.1.A. ...I dunno. A modified tub cost you 50 lbs in the Mod classes. Attached image(s) |
URY914 |
Dec 28 2010, 06:37 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,354 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
URY914 |
Dec 28 2010, 06:40 PM
jt914-6 |
Dec 28 2010, 07:03 PM
Driving & working on teeners 41 years Group: Members Posts: 1,785 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
A couple more of Wayne's car....9146.....
URY914 |
Dec 28 2010, 07:47 PM
^ I see sails.
grantsfo |
Dec 29 2010, 08:09 AM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-433-1293632621.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.race-cars.com-433-1293632350.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.powertechracing.com-433-1293631975.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.powertechracing.com-433-1293632113.1.jpg) This post has been edited by grantsfo: Dec 29 2010, 08:23 AM |
Randal |
Dec 29 2010, 10:41 AM
Sure does look different, but with the high hoop and the bars running back to the shock towers not bad. (IMG:style_emoticons/default/sawzall-smiley.gif) |
Brett W |
Jan 3 2011, 02:32 PM
Sure does look different, but with the high hoop and the bars running back to the shock towers not bad. (IMG:style_emoticons/default/sawzall-smiley.gif) That cage isn't legal for SCCA. The rear down bars can't have a bend in them and be legal for SCCA and NASA. |
Randal |
Jan 3 2011, 03:16 PM
Sure does look different, but with the high hoop and the bars running back to the shock towers not bad. (IMG:style_emoticons/default/sawzall-smiley.gif) That cage isn't legal for SCCA. The rear down bars can't have a bend in them and be legal for SCCA and NASA. You are right, no bends allowed in SCCA. Good news is that mine aren't bent, but cutting the sail off would cost me 50lbs in EMOD; someone could argue that cutting the sail off is cutting part of the tub. Anyway easy math on that one given the net weight savings removing the sail is +/- 16lbs. |
J P Stein |
Jan 3 2011, 05:24 PM
Good lookin' cage, Randal.
grantsfo |
Jan 5 2011, 03:19 PM
Shouldnt there be a bar behid the seat to be SCCA and NASA legal? Do they allow you to mount harnasses to firewall?
URY914 |
Jan 5 2011, 05:19 PM
Cut the outside skin off the sail then cut out all the heavy sheetmetal inside it. Or do what I did and make one in fiberglass.
Randal |
Jan 5 2011, 07:20 PM
Shouldnt there be a bar behid the seat to be SCCA and NASA legal? Do they allow you to mount harnasses to firewall? That is next in the process. In reading the rules you can mount the shoulder harness to the firewall like JP did. He used big fender washers. I am going to have a bar running from the hoop to the hoop cross bar, which is shown in the picture as a piece of tape. |
Randal |
Jan 5 2011, 10:47 PM
URY914 |
Jan 6 2011, 05:52 AM
Thanks Randal, I used the chrome trim pieces to maintain the shape of the piece and it worked pretty well.
bcaschera |
Mar 3 2011, 12:28 AM
Member Group: Members Posts: 73 Joined: 1-October 09 From: san jose Member No.: 10,873 Region Association: None |
I dont know if it is worth 50 lbs. but the targa bar from sail to sail is about 20 lbs. alone. (That is all that is left from my trarga bar).
Is this really a worth while mod? aren't you sacrificing quite a bit of rigidity by cutting the sails? |
Randal |
Mar 4 2011, 07:58 AM
I dont know if it is worth 50 lbs. but the targa bar from sail to sail is about 20 lbs. alone. (That is all that is left from my trarga bar). Is this really a worth while mod? aren't you sacrificing quite a bit of rigidity by cutting the sails? Thanks for the information. I've gone off doing this project for two reasons, one of which you outline above, i.e., although 20 lbs is a lot, the negative is that you could get protested for cutting into the tub, per SCCA. That wouldn't be a good thing. |
jjackson |
Apr 2 2011, 04:16 PM
Member Group: Members Posts: 219 Joined: 5-October 10 From: maumelle, arkansas Member No.: 12,246 Region Association: None |
I dont know if it is worth 50 lbs. but the targa bar from sail to sail is about 20 lbs. alone. (That is all that is left from my trarga bar). Is this really a worth while mod? aren't you sacrificing quite a bit of rigidity by cutting the sails? Thanks for the information. I've gone off doing this project for two reasons, one of which you outline above, i.e., although 20 lbs is a lot, the negative is that you could get protested for cutting into the tub, per SCCA. That wouldn't be a good thing. Cage work looks great!! What class are you building it for? The season after I cut away the most metal-we broke/fatigued the rear of our old chasis to the point that the car NEVER handled correctly again.So be careful.In some ways it was a blessing-we kept upgrading suspension components until we found the problem-Several frustrating seasons-we got really smooth driving a flexing chassis.JJackson |
Randal |
Apr 8 2011, 10:34 AM
I dont know if it is worth 50 lbs. but the targa bar from sail to sail is about 20 lbs. alone. (That is all that is left from my trarga bar). Is this really a worth while mod? aren't you sacrificing quite a bit of rigidity by cutting the sails? Thanks for the information. I've gone off doing this project for two reasons, one of which you outline above, i.e., although 20 lbs is a lot, the negative is that you could get protested for cutting into the tub, per SCCA. That wouldn't be a good thing. Cage work looks great!! What class are you building it for? The season after I cut away the most metal-we broke/fatigued the rear of our old chasis to the point that the car NEVER handled correctly again.So be careful.In some ways it was a blessing-we kept upgrading suspension components until we found the problem-Several frustrating seasons-we got really smooth driving a flexing chassis.JJackson I'm probably going to run E Mod, but will be underpowered when going against the monster cars. But it will be fun and we'll see if a good handling car can get within shouting distance. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 10:20 PM |
