> Why are Hella H4 60/55's not DOT Approved?, I don't get it
ellisor3
post Dec 29 2010, 06:15 PM
HPWhore
I ordered a Hella H4 Conversion kit and noticed that is says that it is NOT DOT Approved . OK Why NOT??
http://www.sierramadrecollection.com/store...tail&p=2622
post Dec 29 2010, 06:23 PM
Resident German
QUOTE(ellisor3 @ Dec 29 2010, 04:15 PM) *
OK Why NOT??
Because someone didn't want to pay through the nose to get a DOT approval ...
McMark
post Dec 29 2010, 06:33 PM
914 Freak!
914Sixer
post Dec 29 2010, 06:37 PM
Don't worry about the DOT approval. Just put them in and use them. Most inspection stations only see if the work.
helios
post Dec 29 2010, 07:42 PM
Because they actually work. (IMG:style_emoticons/default/lol-2.gif)
I believe another part comes from the fact they don't scatter enough light (due to headlight standards from the '60s & '70s). I don't believe any of the standards changed until recently w/ the release of OEM HIDs (not talking about the drop-in kits).
ellisor3
post Dec 29 2010, 07:49 PM
HPWhore
QUOTE(SirAndy @ Dec 29 2010, 07:23 PM) *
OK Why NOT??
But there are other Hella's that are DOT approved, right?
post Dec 29 2010, 08:17 PM
Resident German
QUOTE(ellisor3 @ Dec 29 2010, 05:49 PM) *
Sure. My guess is that those are for a much larger target market and thus justify the expenses for the DOT approval ... (IMG:style_emoticons/default/popcorn[1].gif)
detoxcowboy
post Dec 29 2010, 09:34 PM
Region Association: Africa
From Pelican Parts there is an h4 that is not approved they call "euro" or it says "euro" on the box when you get it, then they also have h4 DOT approved. I have had both and the glass is just cut different w/ the DOT one having 3 large raised nipples on each and more cuts and the one that is DOT approved has the "DOT" mark raised on the glass cost more but is the legal one.. you can put 55/60 or 55/100 whatever.. The "euro" do not look legal few cuts and very flat, The DOT look more vintage but it is apples and oranges basically (IMG:style_emoticons/default/agree.gif) it is money to the government which is why they cost more I presume, but Cops can be pricks
and probably just a fix it ticket but it gives the "man" reason to check you out, if your burning one your screwed. I switched to DOT and like them better but when lighted I think the "euro" appeared brighter off hand. I also run the 55/100 with no relay and no problems even running all night through Big Sur more or less alone on the highway with using 100watt brights mostly for a couple hours, nothing melted nothing burned.
helios
post Dec 29 2010, 11:37 PM
If you scroll down toward the bottom of the page, you can see the difference between a standard DOT and E-code beam pattern. There is more to it than just the lens flutes.
Daniel Stern Lighting
E-codes focus more light on the road, and less into the trees. In fact there is very little light that will reach trees and signs directly above the vehicle. The beam does have a kickoff up to the right to light up roadside signs.
I'm running E-codes on both the GLi and the 914 and absolutely love them (I absolutely hate the stock headlights on the Mustang). They do take a little getting used to not seeing a bunch of light in the trees though for the first while. I've also got the headlamps on the GLi relayed as well, so I'm not losing a bunch of voltage through the switch and all the wiring under the dash (dramatic increase in light on older cars). The amount of light they actually focus on the road is payoff for me. I've yet to be hassled about them, but I don't run these blue/purple HID drop-ins in DOT housings that all the kids are running nowadays.
SGB
post Dec 30 2010, 09:06 AM
just visiting
I disagree that inspectors won't notice. I think some would. It is pretty obvious that DOT lenses have the alignment tits. Most inspectors have a book (well, database) showing what the underhoood area for each and every vehicle should look like. I'm guessing they also have a little direction about DOT lenses and other things applicable to all. It's low hanging fruit for 'em.
I know people in VA who keep the old ones around for that yearly re-installation...
aircooledtechguy
post Dec 31 2010, 11:57 AM
The Aircooledtech Guy
Inspection station?? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif)
We don't need no stinkin' inspection station. . . here anyways (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/av-943.gif)
detoxcowboy
post Dec 31 2010, 12:31 PM
Just for everyones info, I just noticed your link.. those h4 are cut simular but different the the "Euro" ones at Pelican, (say Euro on the box when you get them but not in the h4 listing) the "Euro" have less and differnt angle cuts and are flatter in appearnce..
- Lo-Fi Version Time is now: 16th July 2025 - 06:01 AM
