13" wheels+tires for 914 racer, what would be pros n cons? Any experience? |
Chris Pincetich |
Dec 31 2010, 07:25 PM
What do you all think about an ultimate wheel/tire advantage going 13" wheels vs. 15" wheels? For AX or track? This would be for a second set of race only wheels+tires.
I know a local guy who did the mods to use 13" wheels on a 914. This is the first I have seen it done, but I don't have decades of racin experience either. 13" seems to have plenty of available race tires that are cheaper (very cheap as race-track throw-aways). Getting wheels may be a custom job, that's what my friend did, but maybe there are VW bugs or other 4x130s (or 5-lug P-car) racers that have used wheels? Very interested in your insight into physics and experience of 13s vs. 15s. I have seen lots of fast SCCA cars with them. (IMG:style_emoticons/default/beerchug.gif) Happy New Year! |
URY914 |
Dec 31 2010, 08:38 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,411 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
First: you better check your rule book if you're going to a/x w/ 13" wheels. You just moved into the modified class.
Second: On the track you will change your gears so much you'll probably be slower overall. |
DanT |
Dec 31 2010, 08:46 PM
Chris, to touch on one of Paul's points.
Zone 7 PCA does not have any rules currently that address wheel diameter, only wheel width. |
Chris Pincetich |
Dec 31 2010, 09:28 PM
With the carbon fiber body parts I have, I already land in modified. No worries!
(IMG:style_emoticons/default/beerchug.gif) As DanT knows, I am usually at the PCA events, hoping to be in the top half. I would do this to be faster at AX, have wheels+tires that fit inside for transport better, and because faster wheels are cheaper than a faster motor right now. |
DanT |
Dec 31 2010, 09:42 PM
top half is what I have in mind for my stock '75 on street tires for next season....should be great for my PAX results. (IMG:style_emoticons/default/smilie_pokal.gif)
see you out there Chris... the 13" wheels/tires are definitely an interesting mod. (IMG:style_emoticons/default/biggrin.gif) |
J P Stein |
Dec 31 2010, 09:45 PM
Wheels & tires are lighter...if ya don't buy steel wheels. R25 Hoosier cantis are available. Good grip but quick wear.
BKLA |
Dec 31 2010, 09:59 PM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
DanT |
Dec 31 2010, 10:11 PM
caliper needs to be changed
see a thread here 13" wheels and tires on a 914 (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 6th May 2024 - 04:19 PM |
