| johannes |
Jan 7 2011, 02:17 AM
Club Porsche 914 France member since 2005 ![]() ![]() ![]() ![]() Group: Members Posts: 3,092 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
https://www.youtube.com/watch?v=6JC2N3G3YWo Nice three wheeler (IMG:style_emoticons/default/happy11.gif) |
| JmuRiz |
Jan 7 2011, 12:49 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,619 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
Sooooo hot.
| sean_v8_914 |
Jan 7 2011, 02:27 PM
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
neeeds more rear spring. too much squat. 4 wheels grip better than 3. his chassis dynamics suck
| TC 914-8 |
Jan 7 2011, 02:50 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 840 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest
Can't wait for Dieter to translate all's I got was Riverside and Daytona
Otherwise awesome who gives a crap on the chasis dynamics (IMG:style_emoticons/default/poke.gif) |
| Drums66 |
Jan 7 2011, 03:03 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
....say what?(Chassis dynamic's. could save his fuching life) (IMG:style_emoticons/default/biggrin.gif)
(IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)(very nice ride!!!!!!) |
| RFoulds |
Jan 7 2011, 03:19 PM
914Rennsport ![]() ![]() ![]() Group: Members Posts: 861 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region
If he is lifting inside tire that easily, he needs:
Stiffer rear springs less torsion in the front sway bar I had same issue on 914-6. Car was set up perfect when I ran street tires. Once I had Hoosier track tires, I was lifting inside front tire. The extra grip was allowing the suspension to squat BEFORE grip would end, sending me spinning. The answer was, changed rear springs from 180 to 200 lbs, and moved adjustable front drop links down one inch. Then, with sticky Hoosiers, I was spot on. Flat through every corner with a nice 5-10 degree angle on a slide if I pushed it. But, as the tires wore, I was spinning because now front was too soft. The big improvement came from cockpit adjustable drop links, allowing me to add in stiffer front as the tires went away. Got the idea from Randy Greff in New Orleans from his very fast 911 RSR. |
| Randal |
Jan 7 2011, 03:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Driving at 8 tenths and no helmet. What is this guy thinking? (IMG:style_emoticons/default/chair.gif)
Oh and besides what everyone else has correctly pointed out it looks like the tire combination isn't right, i.e., rears are way to high for front tire set. See the smoke coming out of the wheel wells in the rear? IMHO it's lucky he didn't roll the car on the down hill to the left bit. |
| sean_v8_914 |
Jan 8 2011, 01:10 AM
that car is a frickin marsh mellow pretty boy pinky waiving turd. i love the home boy cross arm driving technique. it complements his suspension set up and throttle mash technique well. that video ranks right up htere with cops, jerry springer and stupid pet tricks...but the car looks cool standing still
| DanT |
Jan 8 2011, 01:15 AM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
looks like the suspension has been that way for a while...
Part of the video shows the hole in the rear flare from tire rub....right thru the sticker on the sponsor sticker... Car is too soft in rear, in a couple of shots you can see tire smoke off of both rear tires at the same time. And yes Randal, I was wondering about the helmetless driver too. (IMG:style_emoticons/default/smile.gif) Also notice he loops it a couple of times, they didn't even bother to edit it out... |
| johannes |
Jan 8 2011, 05:05 AM
In the comments they say the suspension is not set up correctely (street setup) an the rear tires are not the right size.
| smontanaro |
Jan 8 2011, 08:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Can't wait for Dieter to translate... Google is working on translation on-the-fly during conversation (about the 3:28 point in the video): Joy of Stats. How cool would that be? S |
| draganc |
Jan 10 2011, 12:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
In the comments they say the suspension is not set up correctely (street setup) an the rear tires are not the right size. (IMG:style_emoticons/default/agree.gif) the drive commented on it with the remark that this car could/should be used as well for a daily driver. in addition, it's not a real RSR, it's a RS modified to RSR spec. |
Lo-Fi Version | Time is now: 6th March 2026 - 09:54 PM |
