| falconfp2001 |
Jan 7 2011, 11:38 PM
Pancho Pantera ![]() ![]() Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
I just purchased some Bolt on Valve covers and I'm planning on installing them this weekend. They come with C Channel gaskets.
I've seen some of these on bugs and I like the fact that the gasket is secured onto the cover. Anyone have experience with these? Thanks Frank |
| Dr Evil |
Jan 8 2011, 12:22 AM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Hey Frank, I hate to say it, but do a search here for them. Last I recall, they were not looked upon highly due to leaks and such. However, I think that they can be made to work well. I, too, like the idea of bolt on with gaskets retained.
| ME733 |
Jan 8 2011, 06:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
Don"t use them.
| 914Sixer |
Jan 8 2011, 08:53 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,433 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
How many leaks do you want?
| URY914 |
Jan 8 2011, 09:10 AM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 131,679 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
The EPA will be looking for you.
| TheCabinetmaker |
Jan 8 2011, 09:16 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,367 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
What the hell, put em on as long as you already have em. Then you can speak from experience. I wonder how many others who put em down really speak from experience?
| Als914 |
Jan 8 2011, 10:53 AM
Lighting my way ![]() ![]() Group: Members Posts: 330 Joined: 1-January 06 From: Hemet,Ca. Member No.: 5,346 Region Association: Southern California |
I've had mine on since '96 and if installed correctly they don't leak. Each time I remove them for valve adjustments I use the std. cork gasket, sealant on the cover side only, let set for appox. an hour then install them...No leaks
Lo-Fi Version | Time is now: 14th March 2026 - 07:33 AM |
