| porsche4me |
Jan 8 2011, 12:03 PM
Member ![]() ![]() Group: Members Posts: 54 Joined: 27-March 03 From: savannah Member No.: 483 Region Association: None |
Two basic wiring questions : Building a race car from an empty shell - not one single wire in the car !!
#1 -- How many and Where do the wires from the alternator go ?? this is a very basic race car - no fancy electronics - it has Carbs and a pertronix Distrib. #2 --- I have an Ignition switch next to a start button.... I know where the starter button wires go --- But where do I run the ignition "HOT" wire to and from ??? the + side of the coil - thru a fuse - to the + side of the battery ??? Thanks --- cant believe I could not find the answers to my dumb questions --- I guess I must be dumber than the normal race car builder ---- |
| type47 |
Jan 8 2011, 12:24 PM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
This might get you close to your answer:
http://www.pelicanparts.com/914/parts/Elec...lectric_74E.jpg |
| Mike Bellis |
Jan 8 2011, 12:26 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Alternator charge wire goes to the battery. use #6 copper or bigger.
you will need to power the + side of the coil with you "hot while cranking" switch position. |
| porsche4me |
Jan 8 2011, 12:32 PM
thanks - sorry the body is a 76 ---- the motor is a GA 2.0 liter --
-- But there is nothing from a street car left in the race shell -- - I bought a fused distribution block and one one gauge (a tach) --- the factory wire diagram does not help me too much as they run wires to things I don't have, need or want ---- I am looking for the most direct route --- thanks for your help |
| porsche4me |
Jan 8 2011, 12:35 PM
OK - any where else or is that it --- the atlernator has at least 3 wires coming out of it ----- do these cars have an internat voltage regulator ?? you will need to power the + side of the coil with you "hot while cranking" switch position. Ok --- but then off after it starts ??? or hot all the time the engine is running??? thanks |
| Mike Bellis |
Jan 8 2011, 01:08 PM
Alternator charge wire goes to the battery. use #6 copper or bigger. OK - any where else or is that it --- the atlernator has at least 3 wires coming out of it ----- do these cars have an internat voltage regulator ?? you will need to power the + side of the coil with you "hot while cranking" switch position. Ok --- but then off after it starts ??? or hot all the time the engine is running??? thanks Some alternators need a field signal. It usually is a lamp in the dash. One side of the lamp is connected to 12V and the other to the alternator. On some alternaters you also have a second wire that goes to the battery as Ref signal. You may have an external voltage regulator. Easiest would be to get a Chevy 1 wire alternator. You can go to the painless perfomance web site and find basic wiring diagrams for race cars. The charge wire goes to the battery. A wire from the battery goes to your ignition switch. The hot while cranking wire is also hot with engine on. If you apply power to the + side of the coil and spin the engine, the engine will start (if Carburated). remove power from the + and the engine will stop. |
Lo-Fi Version | Time is now: 29th April 2026 - 09:10 PM |
