| dflesburg |
Jan 9 2011, 09:43 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,722 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
Here is the deal.
I am looking for a Transaxle like the G50 but need an automatic. Need to have a really long shift cable and a column shifter in a mid engined rear wheel drive hot rod my friend is making. |
| TheCabinetmaker |
Jan 9 2011, 09:51 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,358 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Hot rod? Automatic? (IMG:style_emoticons/default/huh.gif)
| messix |
Jan 9 2011, 09:58 AM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
| computers4kids |
Jan 9 2011, 10:04 AM
Love these little cars! ![]() ![]() ![]() ![]() Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
| IronHillRestorations |
Jan 9 2011, 02:20 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,897 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
There's too many electronic components required for any of the Porsche Tiptronic transmissions, so that's off the table. By the time you got done putting one in a 914 you'd be better off just getting a Tip Boxster.
| Mike Bellis |
Jan 9 2011, 02:36 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Get one from an Audi 5000 Front Wheel drive. No electronics needed.
| Steve |
Jan 9 2011, 07:13 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,982 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
| Mike Bellis |
Jan 9 2011, 07:48 PM
| Dr Evil |
Jan 9 2011, 07:53 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Why not a trans out of a 70s car like a Torino or caddilac ? Arent those front wheel drive and take V8s?
| Mike Bellis |
Jan 9 2011, 08:05 PM
| Dr Evil |
Jan 9 2011, 08:08 PM
I didnt know they were sideways, learn something new every day.
| Mike Bellis |
Jan 9 2011, 08:13 PM
| dflesburg |
Jan 9 2011, 08:22 PM
no we are off track here....
The project is... Mid engine V8 in a VW Bus... Trying to work out how to use a Corvette motor with a transaxle like a vett but the transaxle needs to be as close as possible to the motor... Column shifter is not manditory. We could mount a floor shifter. Automatic is preferred due to avoiding rigging a clutch and shift linkage. |
| Andyrew |
Jan 9 2011, 08:26 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
Get one of the newer 5 speed audi FWD trani's. Found in Passat v6's and audi fwd's.
| r_towle |
Jan 9 2011, 08:30 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
928 tranny...plentiful.
Kennedy has adapter parts already made up.... 944 also... In the bus, you have enough length to do it and just shorten the torsion tube and shaft. Rich |
| Mike Bellis |
Jan 9 2011, 08:33 PM
A side shift 901 Trans from a 914 would be easy to rig. Use some pillow blocks and u-joints for the shift rod. The tranny already has a pulley for the clutch. You just need a longer cable.
If you want to go Audi auto, search for the 914 auto thread by Computers4Kids (spelling). He bought a converted car from SoCal. The 1999-2001 VW Passat also has an auto that will fit. A 2wd version of the same tranny can also be found in many Audi's. Make it real easy and buy an wrecked Audi V8 or v6 Turbo and use that engine/tranny/computers in the bus. |
| Jacob |
Jan 9 2011, 08:44 PM
Member ![]() ![]() Group: Members Posts: 131 Joined: 12-February 08 From: Mansfield, Oh Member No.: 8,705 Region Association: Upper MidWest |
The "Unitized Power Package" (UPP) was used in first, second and third generation Toronados (1966-1985) and was a longitudinal arrangement. The "sideways" mounted drive trains did not appear until the 1986 model
| Dr Evil |
Jan 9 2011, 08:58 PM
Re-gear a power glide from a corvair. I have the corvair engine and auto in my bus. Link below in my sig. The main issue will be the rotation. The corvair one will turn the opposite way, any one that normally is installed behind an engine will turn in revers if placed ahead of the engine like in the bus.
| jaxdream |
Jan 10 2011, 07:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
The "Unitized Power Package" (UPP) was used in first, second and third generation Toronados (1966-1985) and was a longitudinal arrangement. The "sideways" mounted drive trains did not appear until the 1986 model ![]() Yep , and they weigh around 385 LBS with tourque converter , axles , no fluid. I got one years ago , weighed on the scales at where I worked , they be HEAVY !! Jack / Jaxdream |
Lo-Fi Version | Time is now: 7th December 2025 - 02:38 PM |
