What type of case do I have? |
tornik550 |
Jan 11 2011, 10:37 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I recently acquired several cases. I have been going over each case trying to figure out which is best for my application. I didn't pay much attention to one of the cases until a few days ago. It was clearly a bus case but I cannot figure out exactly what type. Does anybody know the story to this case? Is it a re manufactured case (vw recycle symbol in picture)? If so, is that good or bad? Other than dirt, it is in excellent condition. The registers were not sunken. The bore is nice (per carbon paper test and dial bore gage).
I could not find the typical serial number. The only markings that I could find are pictured. It has a 914 style dipstick, it LOOKS like a stock dipstick. The dipstick is plugged with a metal plug (pictured). The fuel pump boss is set up for a mechanical fuel pump. Does not have a secondary fuel pressure relief piston. The lower oil filler mount is patent (as with buses). Attached image(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 03:14 PM |
