front wheel bearings, change |
tomh |
Jan 15 2011, 12:26 AM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
when changing front wheel bearings do i need new races also or just inner outer and seals?
70 914 |
Jan 15 2011, 01:17 AM
Member Group: Members Posts: 54 Joined: 14-January 11 From: everett wa Member No.: 12,590 Region Association: None |
Sometimes thewheel bearing come with races , change them!
Valy |
Jan 15 2011, 01:18 AM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
when changing front wheel bearings do i need new races also or just inner outer and seals? The new bearings come with new races. I bet you have no idea what brand they are (not interchangeable). Change everything, it's quite simple. I borrowed a race driver from the local Kragen, freezed the races and heated the rotors in the oven. Driving the new racing in took 5 seconds. (If it takes longer, the race warms up and you need to freeze them again) I'm sure people will tell you that you can drive them in without the temperature shock but, I was afraid they will stuck in the middle. Really easy. |
tomh |
Jan 15 2011, 01:33 AM
when changing front wheel bearings do i need new races also or just inner outer and seals? The new bearings come with new races. I bet you have no idea what brand they are (not interchangeable). Change everything, it's quite simple. I borrowed a race driver from the local Kragen, freezed the races and heated the rotors in the oven. Driving the new racing in took 5 seconds. (If it takes longer, the race warms up and you need to freeze them again) I'm sure people will tell you that you can drive them in without the temperature shock but, I was afraid they will stuck in the middle. Really easy. thanks for the info.sounds like i can handle this job |
leebenedi |
Jan 15 2011, 08:04 AM
Newbie Group: Members Posts: 43 Joined: 21-April 09 From: Los Hueros Member No.: 10,284 Region Association: Spain |
This might sound dumb, but how do you remove the cover to access the hub? I am trying to remove them without breaking them (I want to change the bearings also) and I am stumped.
Thanks, Lee |
76-914 |
Jan 15 2011, 10:15 AM
This might sound dumb, but how do you remove the cover to access the hub? I am trying to remove them without breaking them (I want to change the bearings also) and I am stumped. Thanks, Lee A challenge if your used to american cars. There is room to slip a screwdriver behind the cover. Using 2 screwdrivers in concert, one can rock them out. |
leebenedi |
Jan 15 2011, 10:39 AM
This might sound dumb, but how do you remove the cover to access the hub? I am trying to remove them without breaking them (I want to change the bearings also) and I am stumped. Thanks, Lee A challenge if your used to american cars. There is room to slip a screwdriver behind the cover. Using 2 screwdrivers in concert, one can rock them out. Thanks. I will give it a try. |
WFG |
Jan 16 2011, 01:45 AM
Newbie Group: Members Posts: 29 Joined: 6-December 05 From: nashville tenn 37076 Member No.: 5,243 |
This might sound dumb, but how do you remove the cover to access the hub? I am trying to remove them without breaking them (I want to change the bearings also) and I am stumped. Thanks, Lee A challenge if your used to american cars. There is room to slip a screwdriver behind the cover. Using 2 screwdrivers in concert, one can rock them out. Thanks. I will give it a try. why not use dust cap pliers and always replace bearings and races together |
Lo-Fi Version | Time is now: 17th May 2024 - 06:28 PM |
