| Andyrew |
Jan 19 2011, 01:01 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,381 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
Welcome to my Audi Turbo 914 build thread! This first post has been highly edited for your(and my) ease of navigation.
` (IMG:http://www.914world.com/bbs2/uploads/post-172-1428991066.jpg) ` The car 1973 Porsche 914 1.7 w/ appearance group package (IMG:http://www.914world.com/bbs2/uploads/post-172-1429499049.jpg) ` The Story: I purchased this car when I was 14years old and had bought 2 other 914s with it for a measly $1100, The other 2 914’s were basket cases and one had been in a roll over. The previous owner put the 2.0 from the roll over car in this car. I parted out the other two cars and DID A V8 CONVERSION on mine after I couldn’t figure out how to adjust the valves (It seemed easier..). I do a 5 lug conversion as well as put some fiberglass flares on the car and many other things before I decide to paint the car. That is the start of this thread. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1210.photobucket.com-172-1295463716.1.jpg) ` Next I decide that I don’t like how the v8 drives and how I could never keep it cool so I decide to embark on a journey with an engine I was already more familiar with. The Audi 1.8T. To start at the 1.8T engine conversion click below. http://www.914world.com/bbs2/index.php?sho...4780&st=309 Details on the car: Engine: Audi AEB 1.8t Engine, Fully rebuilt, balanced rotating assembly and blueprinted, balanced and clearanced Intermediate shaft. Crankshaft: Stock/polished Rods: Scat Forged I beam rods Pistons: Stock Cams: Stock Valves: Stock intake, Stainless nitrite coated Supertech exhaust AEVN-1103 Valve springs: Supertech high rpm valves SPRK-AUDI18 Piston rings: Goetze 08-502900-00 (Factory stock) Head gasket: Elring Stock head gasket Rod bearings: 034 Dry film coated bearings 034-202-1008 Crank bearings: 034 Dry film coated bearings 034-202-1000 Intake Manifold: Stock Throttle Body: Stock AWM Exhaust Manifold: APR Iconel Stage 3 manifold Exhaust: 3" turbo back stainless steel w/ 2 stainless resonators Intercooler: 700hp air to water core. Turbo: Comp Turbo triple ball bearing CTB5356 Injectors: Bosch 550CC injectors ported and flow matched to 1300CC Fuel Pump: Bosch 044 inside 034 Surge tank Fuel rail: Stock fed with AN10 line Water pump: Davies Craig EWP150 w/ LCD controller MAF: PMAS HPX MAF in 3" housing Boost controller: Cortex EBC Transmission: Audi A4 1.8 5 speed code EHV FWD unit 100mm stub axles from boxster transmission eBay sprung type LSD Wiring: Strip all Porsche wiring, Replace with Audi wiring 100% Engine Management: Modified OEM Audi Ecu Power brakes: Not yet ABS integration: Not yet Traction control integration: Not yet Launch control: Not yet Cruise control: Yes Climate control/AC: Yes OBD2 full control: Yes Check engine light: No smile.gif Front trunk and rear trunk: YES! 8psi: 240whp (Canyon and autox setting) 14psi: 280whp (Street) 17PSI: 300whp (Track and Street driving) (Estimated power goal) 30psi(E85): 400whp (Full tilt mode) Suspension: Raised 911 spindals up front with Koni yellows Mueller Roller Needle Bearings front and rear in leu of all bushings Turbo tie rods 22mm Torsion bars Nascar front sway bar Koni yellows rear 911 rear hubs with 100mm studs Ground control coil over kit in rear 225lb springs Brakes: 911 A calipers front Stock 914 rear calipers Vented rotors front and rear Porterfield semi race pads 19mm M/C Proportioning valve replaced with T Wheels: Boxter rear 17 x 8.5 twists up front with 245 40 17 911 turbo 18 x 10 turbo twists in back with 285 35 18 Body: Rich Bontempi HPH Flares Front and Rear, Molded 916 front and rear bumpers (front bumper to be reworked completely) 6" ducktail spoiler with supports Engman long stiffening kit Seam welded rear Camp 914 hood shocks rear Camp 914 Euro front turn signals Bike rack (IMG:style_emoticons/default/biggrin.gif) Interior(In Progress): Fully custom interior (Still in design phase) Harness Bar 5 point Cam lock harnesses Pepboys Corbeau style seats ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Now that the intro is done, here is my checklist of things that I want to get done with it. Register *5-15-11* Fix ignition **5-30-11** Tune (again) ecu ** Converted back to Carbs after ECU died 5-30-11** Clean goo in trunk (pic) Install Dr window crank *5-30-11* Change oil ****Finished 1-29-11**** Change water pump *Received Remanufactured pump from Slits 1-26-11****Finished Install w/ hangups 1-29-11**** Flush coolant Finish targa bar S *Started progress on the bar* Dr front 1/4 *Sand day 1 1-29-11* *Bondo Day 2-1-11**Primer Day 2-19-11* Dr door *Sand day 1 1-29-11**Bondo Day 2-1-11*[/url]*Primer Day 2-19-11* Rocker pannels *5-7-11* Dr rear 1/4 *Sand day 1 1-29-11**Bondo Day 2-1-11*[/url]*Primer Day 2-19-11* Trunk *Removed spoiler, Plugged old spoiler holes, Long board sanded trunk* Rear bumper *Page 8* Pass rear 1/4 *4-17-11* Pass door *4-17-11* Pass front 1/4 *4-17-11* Front bumper *5-5-11* Hood *Primer 5-2-11* *Paint 5-15-11* Top *5-4-11[url=http://www.914world.com/bbs2/index.php?showtopic=114780&st=120#] Primer sealer *5-15-11* Paint *5-15-11* Radiator cutouts in wheel well (And replace hood with stock) ***Completed 1-26-11*** Fix headlights *6-8-11* Fix horn Finish seat install ****Progress 1-19-11**** ***Finished 1-26-11*** Finish carpet *6-8-11* Finish front sway bar Fix Dr Door handle This post has been edited by Andyrew: Jan 15 2022, 09:16 PM |
Andyrew Andyrews Progress Thread Jan 19 2011, 01:01 PM
Andyrew After
http://www.914world.com/bbs2/uploads/post-17... Jan 19 2011, 01:04 PM
kg6dxn AWESOME! :Qarl:
I want you to drive and enjo... Jan 19 2011, 01:26 PM
Andyrew At this point its either... Im even entertaining a... Jan 19 2011, 01:37 PM
underthetire Going to be one hell of a ride :D
I'm thinkin... Jan 19 2011, 01:41 PM
pt_700 will be following this with great interest as i pl... Jan 19 2011, 01:49 PM
Andyrew F.I setup: Its actually a pretty great unit, HOWEV... Jan 19 2011, 02:18 PM
shoguneagle WHAT???? YOU HAVE NOT BEEN WORKING OR DRIVING ... Jan 19 2011, 05:59 PM
SGB Sounds like a rocket.
You should look at Tangerin... Jan 19 2011, 07:05 PM
arkitect Andrew,
Go with a Audi engine like you want, don... Jan 19 2011, 09:16 PM
Andyrew Got some progress done on the Pass side seat.
The... Jan 20 2011, 01:24 AM
ernestj911@gmail.com This is a great 914 one the inspirations for me to... Jan 21 2011, 12:54 PM
Gint Is it done yet? :evilgrin: Jan 21 2011, 08:20 PM
Andyrew :D
Nope, Very little going to be done today... I ... Jan 22 2011, 02:08 PM
Andyrew No progress tonight on the 914, however I did spen... Jan 25 2011, 01:19 AM
Andyrew Finished the seat install!! I actually did... Jan 26 2011, 11:16 PM
Lennies914 Looking good Andrew. Is that an orange band badge ... Jan 26 2011, 11:22 PM
Andyrew
Looking good Andrew. Is that an orange band badge... Jan 27 2011, 12:26 AM
kg6dxn :Qarl: :Qarl: :Qarl: :Qarl: :Qarl: :Qarl:
... Jan 26 2011, 11:39 PM
Justinp71 Lookin Good! Jan 27 2011, 12:38 PM
Andyrew Thanks!
Progress from lunch today.
All radi... Jan 27 2011, 02:21 PM
Andyrew Progress from today!
Finished removing the w... Jan 28 2011, 05:48 PM
matthepcat Right on. Just get her driving again, and you will... Jan 28 2011, 07:55 PM
kg6dxn It looks like nothings wrong with that pump. Most ... Jan 28 2011, 08:25 PM
Andyrew Replace it anyways. Its the pump that came with my... Jan 28 2011, 11:16 PM
Andyrew Progress so far today. Been working since 9am, unf... Jan 29 2011, 07:56 PM
kg6dxn I like Mopars. Here's a pic of my old car...
... Jan 29 2011, 08:02 PM
Andyrew Thats a bad ass mopar mike! Jan 29 2011, 08:21 PM
Andyrew Bit the bullet.
Started ~ 8 finished ~ 11.
htt... Jan 30 2011, 02:08 AM
Andyrew Havent got a working compressor at the house yet s... Feb 2 2011, 12:20 AM
computers4kids Dang Andrew...you really are serious about getting... Feb 2 2011, 09:10 AM
Spoke Lookin' good. Do you have a long board sander ... Feb 2 2011, 09:27 AM
Andyrew Mark,
Yup, To be perfectly honest, I forgot to re... Feb 2 2011, 10:30 AM
orange914 andrew, you planning on spraying it? sounds like ... Feb 2 2011, 06:41 PM
Andyrew
andrew, you planning on spraying it? sounds like... Feb 3 2011, 10:43 AM
kg6dxn Andrew,
What type of flares are those? How wide w... Feb 2 2011, 07:24 PM
McMark Aren't those just 911SC flares? :rotfl:
[Mik... Feb 2 2011, 08:58 PM
kg6dxn
[Mi... Feb 2 2011, 09:09 PM
Andyrew Got some more filler layed down
http://www.914wor... Feb 4 2011, 11:36 PM
computers4kids
http://www.914wo... Feb 5 2011, 10:09 AM
Andyrew They were Yummy!
Today I didnt get near as ... Feb 5 2011, 08:17 PM
Andyrew Got a little progress today before the game starte... Feb 6 2011, 08:39 PM
orange914
http://www.914world.com/bbs... Feb 10 2011, 12:48 PM
Andyrew Finished up sanding the LR fender tonight. I was a... Feb 7 2011, 12:32 AM
Andyrew Made some progress yesteday and today. Not enough ... Feb 10 2011, 01:27 AM
pt_700 i prefer my 914's rather unadorned (in respons... Feb 11 2011, 12:24 PM
Andyrew Haha! Nah, that wouldnt be over the top now wo... Feb 10 2011, 01:16 PM
Beach914 Yup, You need to do a dually rear set up to get ti... Feb 10 2011, 01:38 PM
Hontec Man, that's a lot of work going into filling/s... Feb 11 2011, 06:43 AM
Andyrew Yup, Bodywork is always extremely laborous... Espe... Feb 11 2011, 10:19 AM
Andyrew Well the biggest problem is this car can actually ... Feb 11 2011, 03:42 PM
Lennies914 It's good to see the progress you're makin... Feb 11 2011, 09:11 PM
computers4kids Andrew,
If you ever want to tow your car down her... Feb 12 2011, 09:47 AM
J P Stein Not many lunatics have the urge to modify the targ... Feb 12 2011, 11:09 AM
J P Stein Spoiler?.....yeah, that's the ticket.
If a li... Feb 12 2011, 11:14 AM
Andyrew I'll update this thread tomorrow. Not much to ... Feb 13 2011, 11:45 AM
Andyrew Vday weekend I didnt do much like I said.
http:/... Feb 16 2011, 02:25 AM
kg6dxn :trophy: Feb 16 2011, 09:44 AM
Andyrew Lets start with Friday.
I didnt get near as much... Feb 20 2011, 03:18 AM
Andyrew PRIMER DAY!!!
I should have done some... Feb 20 2011, 03:42 AM
computers4kids Andrew, the car is looking great! I think tha... Feb 20 2011, 08:31 AM
Andyrew It has been amazing having my dad be with me throu... Feb 20 2011, 02:11 PM
dan10101
It has been amazing having my dad be with me thro... Feb 20 2011, 03:18 PM
Andyrew One of my all time favorite pictures of my car :) ... Feb 20 2011, 03:50 PM
JRust Looking great Andrew! Love custom flares. You ... Feb 20 2011, 04:48 PM
kg6dxn Love the progress!
BTW, paint those wheel spa... Feb 20 2011, 06:47 PM
arkitect Andrew,
Great job...making a ton of progress. Are ... Feb 20 2011, 11:54 PM
Andyrew Mike,
Ya I probably should paint those.
Dave,
... Feb 21 2011, 12:29 AM
Gint That's pretty cool. Good prgress Andrew, kee... Feb 21 2011, 09:10 AM
Andyrew Met a local forum member and really great guy toda... Feb 23 2011, 02:03 AM
Andyrew Went to my parents durring lunch and picked up a c... Feb 23 2011, 02:20 PM
Andyrew http://www.914world.com/bbs2/uploads_offsite/i1210... Feb 28 2011, 01:33 AM
Andyrew So I dont have many pictures of the sanding to 220... Mar 7 2011, 02:01 PM
Lennies914 :beer2: Looking great Andrew. WCR this year? Mar 7 2011, 08:31 PM
Andyrew Lennie, Not in the cards this year $$... Mar 7 2011, 09:31 PM
Andyrew http://www.914world.com/bbs2/uploads_offsite/i1210... Mar 13 2011, 11:11 PM
Andyrew No pics today.. I only got a couple hours to work ... Mar 16 2011, 12:52 AM
orange914
(Im pretty sure he wants to paint it black too.. ... Mar 16 2011, 05:33 PM
Andyrew Got some mixed progress done tonight.
Finished g... Mar 24 2011, 12:37 AM
Andyrew My friends geo with what took so much welding. Ful... Mar 24 2011, 12:40 AM
Andyrew This weekend wasnt completely a wash.. I got to wo... Mar 28 2011, 10:48 AM
kg6dxn Great progress! keep going :headbanger:
I ne... Mar 28 2011, 10:53 AM
Andyrew You could build one of these...
http://www.carport... Mar 28 2011, 10:59 AM
kg6dxn
Im contemplating... Mar 28 2011, 11:01 AM
Andyrew Progress from yesterday
http://www.914world.com/bb... Mar 30 2011, 09:39 AM
Andyrew Worked Saturday night and 1/2 the day on Sunday.
... Apr 4 2011, 11:33 AM
Andyrew http://www.914world.com/bbs2/uploads_offsite/i1210... Apr 6 2011, 09:21 AM
kg6dxn Looking good! :beer1: Apr 6 2011, 01:54 PM
Andyrew Progress from today. Laid a bunch of filler/glaze ... Apr 11 2011, 12:26 AM
kg6dxn Nice progress. I'm impressed! :trophy: Apr 11 2011, 08:52 AM
Andyrew Today was spent chasing down light bulbs... Arg...... Apr 13 2011, 12:12 AM
computers4kids
:) Tomorrow Im going to try to convince the GF to... Apr 13 2011, 08:11 AM
Today was spent chasing down light bulbs... Arg..... Apr 13 2011, 08:39 AM
Andyrew :P
I had her weld about 4 years ago.. Turned out... Apr 13 2011, 09:35 AM
McMark Kickin' ass! :headbanger: Apr 13 2011, 10:10 AM
Spoke Car is lookin' good. Love the garage paint boo... Apr 15 2011, 02:56 PM
sawtooth Nice progress :trophy: I hope be painting about a ... Apr 15 2011, 03:45 PM
Andyrew Thanks guys! I was able to get some done this ... Apr 15 2011, 08:48 PM
AZ914 Lookin good man... Apr 15 2011, 08:52 PM
Andyrew Sprayed about 4 layers of primer on... Stupid be m... Apr 16 2011, 12:52 AM![]() ![]() |
Lo-Fi Version | Time is now: 28th November 2026 - 10:07 AM |
