WTB: DWD Rear Boxster Caliper Adapters |
Loser_Cruiser |
Jan 19 2011, 01:10 PM
Member Group: Members Posts: 407 Joined: 4-April 05 From: Bellingham, WA Member No.: 3,873 Region Association: Pacific Northwest |
I know they are no longer produced but I was hoping to find just the rear DWD Rear Boxster Caliper adapter. I already have the front set.
Let me know what you got. Thank you. (IMG:style_emoticons/default/beerchug.gif) |
hwgunner |
Jan 19 2011, 01:50 PM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
Try Clint at Rebel Racing Products (www.rebelracingproducts.com). I think he had some and was looking at making more. Tell him Jonathan Sent you.
jonathan hwgunner (IMG:style_emoticons/default/beerchug.gif) |
Loser_Cruiser |
Jan 19 2011, 02:47 PM
Thanks for the tip, I will see what he says.
Also, still looking if anyone has a set thats collecting dust. (IMG:style_emoticons/default/smile.gif) |
IronHillRestorations |
Jan 19 2011, 04:10 PM
You might also try Rich Johnson, a914guy@aol.com
Loser_Cruiser |
Jan 19 2011, 04:54 PM
I did contact Rich already. He was very helpful and I will probably go with his if I can't get a hold of any DWD mounts. Rich said that the pad had to be modified in order for the caliper to work when using his mount and I am under the impression that the DWD does not require this, plus I have the DWD front set. Thanks for all the help so far.
okieflyr |
Jan 21 2011, 07:09 PM
9fauxteen Group: Members Posts: 816 Joined: 9-January 05 From: Phila PA Member No.: 3,426 Region Association: North East States |
I did contact Rich already. He was very helpful and I will probably go with his if I can't get a hold of any DWD mounts. Rich said that the pad had to be modified in order for the caliper to work when using his mount and I am under the impression that the DWD does not require this, plus I have the DWD front set. Thanks for all the help so far. I bought mine from DWD awhile back. If I remember correctly the DWD did not require pad modifcation on the rear when used with the Boxster rotor as he designed it. I had installed a 911 E-brake system and the boxster rotor did not fit over it as it was too small (I may still have the new set of rotors). I ended up with a big 24mm? 911 rotor and clearancing the pins to allow the fit over the large rotor. I also had to use an add'l spacer to move the adapter and caliper further inboard to center with the rotor. It is working ok, but i'd like to lighten things up with a smaller rotor and not have to use the spacer. Clint @ Rebel Racing may be able to set you up as well. |
davesprinkle |
Jan 21 2011, 09:27 PM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
I've got a set I'll sell. Send me a PM.
BKLA |
Jan 22 2011, 02:48 AM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
The DWD set is designed to work with the boxster disc (rotor) and rich johnson's is designed to work with the vented 911 rear rotor. Two completely different setups. Rich's are more substantial with less machining that the DWD setup. No judgement, just observations. The RJ mount would work with the 911 Ebrake setup without mods.
Steve |
Jan 22 2011, 07:47 PM
914 Guru Group: Members Posts: 5,587 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I'm running the RJ mount and the 911 ebrake assembly. It was really simple to grind down the pads for the 911 rotor. I live in a hilly area and its nice to have an emergency brake. The boxster brakes are awesome on a 914. I have the RJ adapters front and rear. Work great!!
Loser_Cruiser |
Jan 24 2011, 01:38 AM
Thank you everyone, I think Im takin care of now! (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 17th May 2024 - 07:22 PM |
