QUOTE(Loser_Cruiser @ Jan 19 2011, 05:54 PM)
I did contact Rich already. He was very helpful and I will probably go with his if I can't get a hold of any DWD mounts. Rich said that the pad had to be modified in order for the caliper to work when using his mount and I am under the impression that the DWD does not require this, plus I have the DWD front set. Thanks for all the help so far.
I bought mine from DWD awhile back. If I remember correctly the DWD did not require pad modifcation on the rear when used with the Boxster rotor as he designed it. I had installed a 911 E-brake system and the boxster rotor did not fit over it as it was too small (I may still have the new set of rotors).
I ended up with a big 24mm? 911 rotor and clearancing the pins to allow the fit over the large rotor. I also had to use an add'l spacer to move the adapter and caliper further inboard to center with the rotor.
It is working ok, but i'd like to lighten things up with a smaller rotor and not have to use the spacer.
Clint @ Rebel Racing may be able to set you up as well.
