> OT: Sealed bearings, High heat area
Sparky
post Jan 27 2011, 12:29 PM
Mahna Mahna!
The sealed bearings on my pellet stove are starting to howl a little. Instead of spending the $275 for a new combustion and exhuast fan I'd like to try and lubricate the sealed bearings on the existing fan. What type of lube should I use? Was thinking either ptfe or silicone, but what would be best for higher temps?
>M<
r_towle
post Jan 27 2011, 02:47 PM
Custom Member
QUOTE(Sparky @ Jan 27 2011, 01:29 PM) *
>M<
How can you lubricate a sealed bearing without breaking the seal in some way?
Can you remove the bearings?
If so, or to answer your question properly, call Eastern Bearing...
They were in Lowell, but I think they may have moved to Manchester...lemme look.
All they do is bearings...so they will be a good place to ask.
6 Executive Park Drive
North Billerica, MA 01862
(978) 262-9888
Bartlett 914
post Jan 27 2011, 02:49 PM
QUOTE(Sparky @ Jan 27 2011, 12:29 PM) *
>M<
Go to Mcmaster Carr (mcmaster.com) Type in Grease in the search. This will take to a page that has a lot of information about grease. You will want a synthetic grease. There is a lot to choose from with temperature ratings shown.
underthetire
post Jan 27 2011, 03:13 PM
QUOTE(Bartlett 914 @ Jan 27 2011, 12:49 PM) *
>M<
From doing many many high speed spindles, std grease will start breaking down at 140 deg F., and thats what comes in pre-packed sealed bearings. Get high temp grease. You will need to uncover the bearings, the shields always pop right off.
- Lo-Fi Version Time is now: 11th July 2025 - 07:34 AM
